Question about Canon PIXMA iP3600 Photo Printer
Error perinter conon ip3600 code 5c20 - Canon PIXMA iP3600 Photo Printer
3 Suggested Answers
SOURCE: error message 5C20
Error message 5C20
Posted on Aug 24, 2008
  • 214 Answers
SOURCE: Error code 5010 and 5C20
on't know this error code, but this info might help
With thanks to a canon tech Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Posted on May 14, 2009
Conon won't recongnise the cartridge when i just refill it manually?
The cartridges for the IP3600 printer have a chip on them that needs to be reset before the printer will accept the newly refilled cartridge. if you don't have the resetting device then unfortunately refilling these cartridges won't help you at all.
Feb 20, 2015 | Canon Pixma iP3600 InkJet Photo Printer
Erorr 5c20 printer canon ip 3600
why canon pixma ip3600 service error 5C20
Nov 22, 2013 | Epson Stylus Pro 3800 InkJet Printer
Not printing - Flashes 14 times
My printer IP3600 Canon flashes 21 times alternatively between green and orange. It then gives me an Error Code C000. How can this be fixed?
Sep 10, 2012 | Canon PIXMA iP3600 Photo Printer
Can I fix canon error 5C20 myself?
Dial 18002430019 Canon Printer 24/7 find here Canon Printer Customer Service number 24 hour and booming path to get instant technical support for technical problems.
May 07, 2012 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Code d erreur 5c20....l imprimante ne fonctionne plus
Pump roller sensor error or Error Code 5C20
Condition: The pump roller position cannot be detected.
Problems and Solutions:
  • Replace Purge drive system unit
visit this link for more info
http://pcmediks.blogspot.com/2010/11/canon-pixma-error-codes-and-solution.html
Dec 28, 2010 | Canon PIXMA MP620 All-In-One InkJet...
THERE IS AN ERROR IN CONON PIXMA MX308 ERROR CODE U051 COLOR CARTRIDGE ERROR. PLZ PROVIDE THE SOLUTION.
Sep 09, 2010 | Computers & Internet
Error E007 Canon Image runner 2020 Will not finish perinting a document with the above mentioned error
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
Aug 20, 2010 | Canon imageRUNNER 8500 Copier
Canon PIXMA iP3600 Photo Printer Logo
24 people viewed this question
old marine
old marine
