Question about Blaupunkt CDC-A08 10-Disc CD Changer
I can only play discs 1, 2 and 10 - it skips straight from 2 to 10. This is installed in a 2008 Alfa Spider.
  • tristan694 Jul 21, 2009
    Thanks - I think the problem was it wasn't doing a magazine scan and thought I only had 3 discs in there. When I put the changer in without all the cartridges, it did a magazine scan and recognised the other discs. Is there a way to get it to do a magazine scan from the cabin? From my experiments I think if I ever change the discs I will have to do the same thing, i.e. trick it into doing a scan.
    President:
  • 1,734 Answers
Scanning all of the tracks on all
of the CDs (SCAN):
➮ To scan all of the tracks on all of
the CDs in ascending order, press
OK ;for longer than two seconds.
“SCAN” will appear in the display.
Stopping the SCAN function
➮ To stop the SCAN function, press
OK ;briefly.
The track currently scanned will continue
playing.
Note:
It is possible to adjust the scan time. For
more information, read the section on
“Adjusting the scan time” in the chapter
on “Radio Operation”.
Interrupting playback (PAUSE)
➮ Press 3 >.
“PAUSE” will appear in the display.
Stopping PAUSE
➮ Press 3 > during the pause.
Playback will resume.
CD CHANGER OPERATION
Posted on Jul 22, 2009
    President:
  • 2,923 Answers
Are you getting an error message? If yes, what is the exact error message?
Seems that this is a common issue with the Blaupunkt CDC-A08. I searched over the web and found the same problem. Try power cycling the CD changer first.
Turn off the power and make sure to disconnect the power source. Turn it back on after 10 minutes. That should resolve the problem.
If you get the same problem, contact the manufacturer for possible repair.
Hope this helps and have a great day!
Posted on Jul 21, 2009
Headlight adjustment Alfa Romeo Spider 1975
Look in the headlight ring for 2 small cut outs 1 on the side 1 on the bottom insert a Phillips head screw driver in the opening to the set screw and tighten or loosen screw to adjust. You might want to park nose in to a wall and turn headlamps on to check as you work.
Sep 14, 2009 | Alfa Romeo Spider Cars & Trucks
?84 Alfa Spider - electrical isssue
Maybe the switch itself is bad/shorted?
Jun 19, 2009 | 1987 Alfa Romeo Spider
1987 alfa romeo spider graduate no spark
try changing the flywheel sensors. My 86 had exact the same problem, i changed the spark plugs, wires, distributor and finally the good o alfa mechanic found the issue. good luck
Jun 07, 2009 | 1987 Alfa Romeo Graduate
Fuel pump
I have an 89 one in fuel tank and one under car near differential, drivers side
Apr 27, 2009 | 1986 Alfa Romeo Spider
1980 alfa romeo spider rear shock replacement
Nope. There are 2 bolts under the trailing link. Remove them and the single bolt in the top of the shock an you're home free.
Jun 23, 2008 | 1982 Alfa Romeo Spider
2003 alfa romeo spider electric roof does not open
does it have a lock switch somewhere on the dash also check fuses failing that have the roof switch checked
Jun 13, 2008 | 2003 Alfa Romeo Spider Veloce
Blaupunkt CDC-A08 10-Disc CD Changer Logo
87 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
