Question about Samsung Televison & Video
I have a samsung PN43E450A1FXZA Plasma tv. I have no standby light, no power on. I do not have PS-ON voltage or VS voltage on board. Any idea which component on the power board may possibly be bad?
I have checked the PSU board and have 5.3 stby volts, the 15 volts. I do not have VS voltage on power board test spot. I do have VA and VSC voltage as well as SVT_XOUT. I do not have any voltage on any pin on plug CN1201 on main logic board going to the on/off button as well as the standby light on front.
    Top Expert:
  • Samsung Master
  • 75,017 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Dec 28, 2016
Vertical and horizontal lines on samsung plasma tv
Check the Vs and VA voltages to plasma panel. If these voltages, that comes from the main power board is abnormal, this kind of fault can occur. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 19, 2016 | Samsung Televison & Video
Power light flashes 5 or 6 times screen will not light up
There is an internal fuse or capacitor that needs to be replaced. You can try calling Samsung directly for assistance and see it is covered under warranty.
Feb 01, 2016 | Samsung PN43E450A1FXZA PN43E450 43 720p...
Samsung Plasma TV has standby power but no video
Make sure your video and sound cable is working (rca, hdmi cable etc) and your source component like dvd player or settop box is working. If cable is plug into a socket AV 3 or HDMI 3 for e. g. make sure the tv is source or input is selected the same like AV 3 etc.
It is possible for the TV to switch on or off but no picture or sound. This means the input board or tv tuner is faulty in which case you need a good tv repair technician
Oct 26, 2015 | Samsung PN43E450A1FXZA PN43E450 43 720p...
Samsung plasma hp-r4272c, i dont have VS volt output on main power supply board
Just replace the main power supply board if there is no vs voltage output.
Sep 21, 2015 | Samsung HP-R4272 42 in. Plasma HDTV
Sounds like it could be a bad capacitor on the power supply, or possibly on the video out circuit. Bad capacitors are a common problem in Plasma and LCD monitors and T.V.'s.
Jun 25, 2014 | Samsung 51 INCH PS51E530 Full HD Plasma...
LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
Mar 26, 2010 | LG 42PC3D 42 in. Plasma Television
Samsung plasma sp-r4232
Remove the power supply cable to Y Main board, check Vs on power supply board when you turn on tv.
1. If you have normal Vs, replace the Y Main board. If still not work, replace the Logic board.
2. If you don't have normal Vs when you try to turn on your tv, just replace the Power Supply board.
Jan 01, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
Dec 31, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Samsung spn4235 plasma tv
The set will need some screen voltages adjusted on the power supply board, the VS voltage is marked on the panel inside the set, find the VS test point and the VS adjustment potentiometer. adjust the voltage down at least 10 volts, if your not an experienced person in electronics, get a person that is, there is a high voltage on that board that is dangerous
Sep 25, 2006 | Samsung SPN4235 42 in. Plasma HDTV
Televison & Video Logo
55 people viewed this question
Jerry Greenberg
Jerry Greenberg
