Question about Microsoft Windows 98 for PC
Windows 98 install
Hi there
Need some help i am installing windows 98 on asus p4 motherboard with a 1.4 ghz celereon cpu 1 gig mem and a 160 gig WD hdd. Windows 98 installs and everything trough the frist part. when the computer reboots it brings up the windows98 bootscreen and then the p.c reboots again and keeps on rebooting. Please help.
Regards shaun
  • 3 more comments
  • sswan Nov 20, 2007
    hi there
    I did install xp and that is working fine the problem is with 98 se
  • rkenneth Nov 20, 2007
    i lost win98se cdrom to my hp, is there a way to recover it/ download a program on a disk
  • Suji Kumar Nov 22, 2007
    hi i have a problem win98se during installation. its restarting while installing plug and play devices.. my pc config is P4 2.80ghz, INTEL 865 CHIPSET. make: HP COMPAQ. Please give me sol....
  • roys Nov 26, 2007
    MY PC HAS BIG SCREEN AND THE PICTURES ARE NOT CLEAR. I CANNOT GET 32 BIT COLOR PROTOCOL. MY DAUGHTER TRIED DOWN LOADING WINDOWS XP AND THE PC WENT ALL BAD.
  • guddu sahu Nov 30, 2007
    sir my name is Ghanshyam singh i am living from durg (chhatishgar) and job place to micromax computer my pc ditail is asrock mb vai chipset they problam with audio driver for windows 98 . so please give me audio driver send to my email id.
    Problem Solver:
  • 9 Answers
This sounds like you tried to reinstall Windows 98 over the top of an old installation rather than a fresh reformatting of the hard-drive and THEN a reinstallation. You will need to boot from the Windows 98 CD-ROM, FORMAT your hard drive and THEN install Windows 98 as most looping reboot issues have to do with 98 RE-installs over the top of an old installation.
Posted on Nov 30, 2007
  • 37 Answers
It could be a memory related problem. Try to test your memory module by installing it to a different system that is surely working. If that system restarts, then you must replace the memory module.
Posted on Nov 20, 2007
Hi i just built a new PC with 2 x 2gig memory now under computer properties it says 4 gig installed but only 2.99 gig useable and the new motherboard will support upto 16 gig. Using Windows 7 Ultimate...
Looks like one of the 2gb mem card you bought and installed is defective.
Check each one and clean the gold terminals using a pencil rubber eraer, clean it an install it again, move it to side to side just to perfectly fit the contacts.
If both mem card is working the problem would be the memory socket terminal, either it is dirty or the pin connector is burned.
If one is not working, return the mem card and have them replace it.
Hope FixYa helps you out!
Sep 13, 2011 | Computers & Internet
Hi , my name is Nitin and the problem i am facing with my PC is that it gets restarted after every 10 to 15 minutes while playing games and it starts disk checking everytime it restarts. This happens even...
The following tip is not for the same model, but for the same kind of symptoms :
http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/183116-asus-p5p800-p4-3-0ghz-random-reboots.html
Dec 18, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
Cpu speed for ddr 400 ram
cpu speed has nothing to do with ram. they are completely independant. ram speed is important to the FSB (front serial bus) this is the speed at which your motherboard communicates with the devives attached to it. cpu speed refers to how fast a cpu can process info. or how fast it "thinks". most motherboards have the capability of upgrading cpu's. your mobo (motherboard will support the following cpu's:
any pentium 4 up to 3.0 ghz
it supports the following ram
ddr (nott ddr 2 or 3) up to 2 gigs (1 gig each slot) of 533mhz speed (or less)
it also supports up to 2 gigs of sdram either pc133 or pc100
you are using 400 speed ram as you stated i would upgrade to a 533 speed ram as it will be faster, but this is not necessary. as for the cpu just get any P4 (pentium 4) that is 3.0 ghz or less and it will work.
Jun 27, 2010 | ASUS P4S533-MX Motherboard
I cannot configure a SATA RAID 1 to mirror two WD HDD 1 TB
You sure you installed the ASUS RAID drivers when you installed Windows? Ya need to get the drivers off the ASUS disk, transfer them to a floppy, hit F6 when windows tells you to (during windows install...you only have a second or 2 to see the message!)) and use the floppy to install them. Might take a few tries to get it right.
Dec 26, 2009 | ASUS P5GD2 Deluxe Motherboard
Can I use Pentium 4, frequency 3.0 GHz with Asus P4B?
Asus support says the fastest CPU you can use in that MB is a P4 2.6 GHz or a Celeron 2.8 GHz.
For the P4 you need BIOS ver. 1011 and for the Celeron you need ver. 1013.004.
Here is a link to the entire list:
P4B CPU Support
Thanks for using Fixya.
Apr 14, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Windows 98 on P4 DC
Hi there
No ways , first of all Windows 98 doesn't recognise sata drives and will not boot even from a sata dvd writer, there are no drivers for Windows 98 to display correctly and you will have trouble running Windows 98 above 256 MB RAM
Regards
Roger
Nov 12, 2008 | ASUS P4VP-MX Motherboard
Windows Xp sp 2 installation problem
check the cpu fan or remove it then put it again
Nov 08, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
I don't have mother board cd
Hi, I am confused regarding the model of the Mother board
you have:
The P5S800-VM is an LGA775 socket mother-board for a
Pentium 4 CPU.
P4-515, on the other hand, does not return any hits on the
Asus web-site search.
I think your best solution is to contact ASUS /USA:
1-888-678-3688
and talk to customer support.
They will guide you in identifying the exact motherboard you
have, so you can download the driver set from their
support site.
BTW.
I think you computer performance is very unbalanced at 256 MB.
This is not nearly enough memory to run with such a fast CPU,
(2.93 Gigs), and your machine must be terribly disk bound:
1) When your operating system runs out of semiconductor
memory, it begins to thrash to disk, which is 10 million times
slower then RAM, making the fast CPU a total waste of
money.
2) For a normal machine running Windows and a 3Gig CPU
you should have at least 1 GB of RAM, preferably 2GB
(RAM is cheap these days)
But before I put my foot too deep into my mouth, I notice that
you are running FREEDOS, does that mean you are running
DOS only (No Windows ?) for some specialized application ?
Martin
Jul 20, 2008 | ASUS P5S800-VM Motherboard
ASUS P4S533 mother board not supporting full 160 gb
This is happing becuase of your motherboards BIOS !
Really, this happened to me too. You see, our motherboards which are very old cant support above 80 and so on. This is beacuse of the BIOS. You will need to update your BIOS inorder to give new features.
Try go to the Asus home page and download the latest driver for your motherboard. Then install it in your motherboard's BIOS. There is intructions for this in the Asus's home page.
Mar 08, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Microsoft Windows 98 for PC Logo
128 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
