Air conditioner will not start, lights flash for defrost but nothing happens, how do we stop defrost light and start air con?
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
  • 400 Answers
SOURCE: Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Posted on Nov 19, 2009
  • 58 Answers
SOURCE: Air conditioner light flashing
this is usually an indicator that there is a low side high side switch bad or low on freon. does the compressor kick in and out while it is running?
Posted on Mar 10, 2010
iFixapples
  • 57 Answers
SOURCE: 2004 Honda Accord Air Conditioner Not Working
Sorry for the delayed response. For future reference, the blower motor resistor in an 04' Honda Accord is located under the glove box and a little to the left if you are facing it (the glove box). You just need to pull out the plastic panel (yes, you can just pull it out by hand, no tools needed for that). It should be right on the fire wall with a plug going into it. If you reach in there and pull the plug (it has a little notch so it clips into the resistor more securely; make sure you push the clip in) it should have 4 flat prongs on it that go into the resistor. The resistor itself will have 2 phillips head screws that are holding it into the fire wall. Unscrew them and you have the resistor. If you can unscrew both screws before unplugging, it will be easier to see how it unplugs. I know this sounds complicated but once you get in there you will notice it's fairly easy to change out.
Posted on Apr 23, 2010
SOURCE: cant get air con to work it is a teco air conditioner
Ours did the same. My husband checked the manual and found that the filters were FILTHY! The filter is at the front of the inside unit. If you still have the manual it will show you where. This fixed ours as it was NOT working at all!!
Posted on Jul 28, 2010
My LG air con was working and now it's stopped and there is a gree light flashing 7 times the a pause then 7
7 Flash==== Different Operation Mode
Indoor Unit is Set in Different Cool/Heat Operation Mode.....
Jan 14, 2016 | LG Heating & Cooling
Blinking power light
Make sure voltage and polarity is good
Dec 17, 2013 | LG Heating & Cooling
Mitsubishi air con msza24yv. when we turn it on to the heating mode the operation light keeps blinking and nothing happens
Wait 5 mins after turning the unit on to make sure it is not on a pre heat, and if problem is still there check fault code on controller
Jul 04, 2011 | Mitsubishi MSZ-A24NA Split System Air...
Air con makes a loud wooshing noise then goes off. Red light flashes on unit. It's on the heating mode
Its the reversing valve shifting, it normal and you will hear it in the heating mode as well, you will hear it in the heating mode as well, during a defrost cycle.
Jul 04, 2011 | Heating & Cooling
The timer light and the turbo light flashes, plus when I turn the air con on it will turn of 5-10 mins later and the lights will flash
your air con has defect and the sequence of flashing lights are tell us whats the problem. If you have electrical s knowledge we can try to resolve it online, if not is better to call a specialist.
Feb 27, 2011 | Samsung Heating & Cooling
I have a Danby DPAC 8020-5 air con unit. Air con
is there a flashing light on the unit? If so it will correspond to a needed repair. check your manual to match the number of flashes to the warning it is giving you.
Jul 29, 2009 | Danby DPAC8020 Air Conditioner
Outside unit not working
you most likely need a service guy to go out and take a look
Mar 15, 2009 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
