Question about Sewing Machines
How can I sew elastic tightly round toweling to make a cover for a floor polisher?
  • Sewing Machines Master
  • 8,899 Answers
Measure the circumference of the fabric without the elastic. Then decide the fraction of that circumference you need the elastic to be--ie, if the fabric measures 12 inches and the elastic should be three quarters of that length= 8 inches. Cut the elastic to 8 inches. Stitch the ends of the elastic together.
Then fold the fabric in half and mark the halfway points with straight pins, then fold in fourths and mark those points also. Then do the same with the elastic (marked in fourths). Match the quarter mark pins of the elastic to the quarter marks of the fabric. Then stitch the elastic (stretching as you sew) to the fabric. (Marking and matching the quarter marks will insure the elastic will be evenly stitched to the fabric.)
Video How to Sew an Elastic Waistband Without Casing Threads
Sewing Basics 2 7 Ways to Attach Use Elastic
How do you sew elastic on fabric
Posted on Dec 28, 2016
    Top Expert:
  • 41,466 Answers
You stretch it as you sew of course
My sewing machine don't want to work the elastic tread that you use for smocking. I put it on the bobbin. Also, were can I download a free service/ repair manual?
To seek a manual, search the internet for:
Manufacturer + Model + the word "Manual"
Be sure you hand-wind the bobbin with the elastic thread. You may also need to loosen the bobbin tension a bit if the elastic thread is stretching too much while stitching.
Shirring with Elastic Thread
Pretty Ditty Shirring tutorial
How to use elastic thread How to sew with Elastic thread
Tutorial shirring with elastic thread Made By Rae
Dec 02, 2015 | Sewing Machines
Elastic thread pulled too tight in Janome Sewist 525S
I would say your tension spring is shot on your tension assembly. replace it.
Mar 27, 2017 | Janome Sewist 525S Mechanical Sewing...
How to use elastic thread in a Bernette 66
Did you change the needle to one designed for elastic thread?
Aug 21, 2012 | Bernina Sewing Machines
How do I sew Elastic waistband with Husqvarna Viking 910 Surger
I am assuming this is a simple stretch waist band with elastic about 2cm wide attached to a skirt or trousers. You need to measure your wist and cut elastic that length plus 2cm. Then join the two ends by overlapping them 2cm and zig zagging the elastic together with regular sewing machine. Now mark the elastic in quarters, ie hold it flat with the join in the middle and mark each edge with chalk or a fabric removable marker. Then put the marks together and mark the edges again so you have 4 marks equally spaced. Now do this for your garment too. It may be bigger in back so mark front and back, then half this to find the side quarters. Put elastic on inside of garment against raw edge and pin the quarter marks on elastic and garment together. Set up overlocker for 4 thread wide seam. Test seam and adjust tensions if necessary. Now you need to serge the edge of the fabric and elastic together, trimming the fabric but not cutting the elastic and stretch the elastic to fit the garment as you stitch. Elastic on top, fabric right side down underneath. Take out pins before you get near them! Start by lifting the front of the presser foot with your finger and placing fabric and elastic under, then start stitching on and straighten up once the seam is onto the elastic. Dont lift the pressure foot, you just stitch, stop, stretch the elastic to the fullness of the fabric, hold it and seam forward a few inches, then stop and repeat the process. Once right round go over your starting point, then turn and serge off the fabric edge and chain off. Cut, pull the chain to pull it flat and tie a hald hitch in it right up close to fabric. Now turn the elastic band to the inside of the garment. You need to secure it. Usually a straight stitch just onto the lower edge of the elastic with sewing machine from outside.
Dec 27, 2011 | Husqvarna Huskylock Computerized 910
I have a Brother 70 stitch computerised sewing machine. I have managed to fill a plastic bobbin with shirring elastic by not using the little tension knob, only the hook section of it on top of the...
You should not have both, bobbin and top thread filled with elastic, it may screw up your timing. And you are talking major expense to fix. Use regular thread in your bobbin.
Jan 02, 2011 | Brother Sewing Machines
I'm trying to do shirring?
My machines has a shirring foot, so I don;t have the same machine. However, I do not think that elastic thread will work in the bobbin. Have you tried it the other way around? Do you have your manual?
Aug 07, 2008 | Sewing Machines
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
