Question about Sanyo Televison & Video
Sanyo 46848 bright white screen
I purchased a Sanyo tv that had left side dark and ghosting. Having seen the problem before I assumed it was an lcd ribbon that wasn't making proper contact. The tv didn't come with a stand so I had laid it on its back on the table when I turned it on the picture was perfect, but I assumed it was because of the position. I elected to take the cover off and check the lcd ribbons. When o got the metal cover off to expose the lcd panel the screen went bright white with a negative image. I did find a ribbon not making proper contact , but could not get the screen to go back to normal. I'm at a loss
  • Sanyo Master
  • 6,694 Answers
The TCON board or The LCD panel is Faulty.
If you wish to get some details about treadmill repair; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on Dec 28, 2016
Why does my sanyo dp46848 screen go dark but whites are too bright?
First try to gently push the cable between the main board and the LCD controller (T-CON) board and if that doesn't affect the image then replace the T-con board.
Jun 30, 2014 | Sanyo DP46848 LCD TV
Increase in brightness & sometimes switch to "negative" momentarily
he Dell I'm using also has an adaptive brightness, regardless of the fact it does not have a light sensor. It just changes brightness of the screen depending on how much white/black is shown at that moment. Whenever I switch from a very dark to a very bright website I notice and increase/decrease in screen brightness. I'm running Windows 7 by the way.
Good Luck
Jan 01, 2018 | Samsung SyncMaster 2333SW 23" LCD Monitor
Dim/dark screen on my lg50pc3d tv
After its on for 15 minutes, feel the heat sinks on the y board ( on the far left side) if they are cold then replace that and the upper and lower drive boards that attach to the Y main.
Aug 05, 2012 | LG 50PC3D 50 in. Plasma Television
I have a Sanyo 42" LCD tv model DP42649. The
The problem i'm having is, when you turn the tv on it has a split screen with the left side shaken off a little bit. if you give it a tap on the left side it will flicker and the whole screen will come on.
Dec 29, 2010 | Sanyo 42 in. LCD TV
Dark cloud on screen of lcd tv sanyo vizon 42''
sanyo is a junk tv, and I will NEVER purchase another....less than 5 years old black clouds on the screen, repairs are cost more than the cost of a new tv.....
May 06, 2010 | Sanyo Vizon LCD-15A2 Television
I have a Sanyo 46 inch flat screen hdtv purchased from walmart aug. 31rst, 2008. Sure enough, 13 months later my tv is having picture problems and getting worse. It started having portions of the screen...
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
Nov 01, 2009 | Sanyo DP46848 LCD TV
Samsung digimax i5
You are having the following problems:
White balance setting incorrect.
images are too bright
ㆍExposure is excessive
→ Reset exposure compensation
● Adjusting LCD Brightness
1. In any mode with the exception of Voice Recording mode,
press the MENU button.
2. Press the LEFT/ RIGHT button and select the [Setup]
menu tab.
3. Select the [LCD] menu by pressing the UP/ DOWN button
and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN
button and press the OK button.
[LCD] sub menu : Dark, Normal, Bright
5. Press the menu button twice and the menu will disappear.
Turn camera off. Try removing the fully charged batteries for 30 seconds, reinsert batteries and turn camera on. Hope this helps.
Dec 10, 2008 | Samsung Digimax i5 Digital Camera
Ghost image
You will have to replace both the convergence IC's on your TV..
Oct 23, 2008 | Sanyo PLC-XR70N 70" LCD Monitor
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
32 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
