Question about Polk Audio RT400 Speaker
A crackling sound emanates from one of the woofers, I might need to replace it; the part number ismw8002. Where can I order a replacement ?
    President:
  • 1,126 Answers
Http://www.crutchfield.com/brands/Polk-Audio/
You might give these folks a try.
Posted on Jul 21, 2009
Crackling subs
After crackling sound they stop and the light on overoald
Dec 29, 2013 | Legacy 12 500 watt l series woofers,...
Dell xps 15 L501x sub woofer giving crackling sound
hi you can detached or disconnected the subwoofer cable, for temporary or permanent fix, as the speaker sound also produced good quality sound..
here how i disconected the subwoofer cable, it easy to find at the bootoom, see also utube video inside the link given below
http://atozcs.net/dell-xps-l501x-subwoofer-produce-distorted-crackle-sound/
Aug 09, 2013 | Dell Xps 15 L502x Subwoofer Speaker Pn57g
Picture quality is dim. There's also a continuous crackling sound emanating from the rear area, I believe in the area where the lamp goes. Is this merely a lamp problem?
check the lamp ballast board which may the cause of dim and crackling sound. check for bad high voltage transformer and dry joints connector at the ballast board.
Sep 07, 2012 | Hitachi 50VS810 50" Rear Projection HDTV
Crackles even after blades are cleaned
To stop the crackling sound, you need to remove all of the dust particles from the wire in the back. Sometimes when the unit is extremely dirty you can see sparks emanating from the wire, this is what causes the crackling sound. The unit has a built in cleaner you can lift up and down to perform this task, located on the top, but this doesn't work extremely well.
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. To do this, approach the unit from the front, and turn the blade door slightly so the wire can be seen. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Oct 19, 2011 | Ionic Pro TURBO Air Purifier
My bass makes a crackling noise it never used to have this problem, i put this little faggy magnet near it and i think its the cause
Sounds like you turned your system up beyond it's capabilities... aka blown woofer. Buy a new sound system from www.pcrepairshop.org and that crackling noise will be gone for good, guaranteed!
Jul 10, 2010 | Logitech X-220 Computer Speakers
Powered Sub Woofer emitting lound crackling noise
i would say so sounds like woofer is dying unless u pull it apart and replace the woofer it doesnt have to be same brand just same size and watts and ohms then u can keep it
May 28, 2010 | JBL 5.1-Channel Home Theater Speaker...
My Aiwa powererd sub-woofer TS-W50U) has crackling sound.
Crackling is an unusual noise but typically indicates a bad capacitor in the amplifier board. This can be a rather costly repair but first we will go through basic trouble shooting steps.
Reduce the volume on the sub and see if the noise remains and changes with the volume.
Unplug the sub and disconnect interconnect cables. With both hands push softly on the speaker cone to move it in, let it back out and do this a few times. If you hear a scraping noise and some resistance your driver is misaligned and you need to recone or replace the driver.
Check all your interconnect cables, there may be a bad internal connection (usually causes pops and cut-outs).
Let me know how things workout. If it makes the crackling noise at all volumes and the driver seems fine then I would seek a professional to repair it, or replace.
Cheers,
Kevin
Feb 09, 2010 | Aiwa Audio Players & Recorders
No clean air smell/crackling & static
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Not sure about the smell though. Mine has started to smell a little strange and I haven't figured out how to fix that problem.
Oct 01, 2008 | Ionic Pro TURBO Air Purifier
M-Audio BX8 blows a fuse
If your monitor is crackling and fizzing, that is not a fuse issue, unless the fuse you have installed is underrated. It sounds like you have a bad driver/woofer, and need to get it replaced. CLICK HERE FOR THE REPLACEMENT DRIVER for this model.
- DJPA
Jul 05, 2007 | M-Audio Studiophile BX8 Main / Stereo...
Crackling Sound From Subwoofer
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection.  Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out.  See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
Jan 21, 2007 | Altec Lansing 221 Computer Speakers
343 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
