Question about Cameras
How can I cancel the delete button with dmc-sz8 . I am trying to import the memory 8gb to my ipad all I can see is delete selected..not showing the import selected.
pauman
  • 248 Answers
SOURCE: I can't delete photos.
try to press down instead.
Posted on Mar 08, 2009
  • 191 Answers
SOURCE: cancel ''write protect'' on USB memory stick
If no physical switch, then check the software that came with. Some sticks have a software component that recognizes when you plug the stick in and gives you options for viewing and launching applications from the stick. There may be controls you can use to change the write protect.
If not, or you can also try, opening a view to the stick from Windows Explorer and just delete files from there as you would from any drive. Windows will prompt you to confirm delete. I wouldn't delete any auto-load or setup apps that would be used to connect to another computer.
Posted on Oct 05, 2009
callonafo
  • 174 Answers
SOURCE: says this memory card is protected - can't take
Kindly follow the steps below
Remove the memory card from the camera.
Look at the memory card very well, you will see a slide switch on the side edge of the memory.
Move the switch to the unlock position.
Put the memory card back to the camera.
You can then start using it.
Thanks
Posted on Oct 18, 2009
SGNath
  • 170 Answers
SOURCE: Lumix DMC-LC33 shows memory card error -format
This normally happens when the memory card gets corrupt. Hope you have pressed OK after selecting YES. Check whether the card is locked. SD card has a small Lock button on the top left. If this fails, buy a new SD card and format it in the camera before taking any image.
Posted on Dec 13, 2009
  • 11967 Answers
SOURCE: How do I transfer pictures
Go into the menu and find "copy"...this gives you the option to copy the internal memory to a memory card.
Posted on Oct 10, 2010
What setting to use to transfer photos to iPad via USB adapter from apple
Just go to the photo app (even when you don't have any pictures there) as soon as the adapter is plugged in, you see import on the bottom of the screen. press that then goto the top of the page again press import, then all or selection. When ready please don't press delete, because the pictures will be deleted from the card.
Mar 16, 2015 | Panasonic LUMIX DMC-LF1K Black Digital...
How to delete a photo on an iPad after its been transferred to a computer?
Go into your photo app > Hit select > Select the photo you want to delete (tap on the photo - you should see a check mark on the photo when it is selected) > Select the Trash-Can icon > Select Delete Photo. If you have iOS 8, it may show up in Recently Deleted Photo's list. You can simply delete it from there by repeating the same steps.
Feb 13, 2015 | Apple Ipad I-pad
How do I delete photos off the camera roll without deleteing them off the album
There are two methods to delete photos from iPad Camera Roll:
1. Import the Camera Roll to your computer, choosing to delete photos after import.
2. Delete photos from your iPad manually. Open the Photos application, open the Camera Roll, tap the Action button, tap each photo to select it, and tap the Delete button.
Note: For photos you want to save for later, import them to your computer before deleting them from the Camera Roll.
Aug 23, 2012 | Tablets & eReaders
How to delete photos from the Ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to delete the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to delete from the iPad under the Sync Photos from heading.
5.If you want to delete all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
Done.
If it can't work, you can refer to the article about Delete photos from iPad.
Good Luck!
Jun 25, 2012 | Apple iPad (16 GB) WiFi Tablet PC
How to delete apps
You can either delete them from itunes when you plug in your ipad click on the devices and select your ipad then under the tab app you can then choose the apps you want to be on your ipad. Or on your ipad itself press your finger onto the any of the apps until they start shaking on screen the ones you can delete have an"x" in the top left hand corner of their icon, you then click on the "x" and it will then ask "Delete app, Deleting "app"will also delete all of its data" then select delete or cancel. Once you have deleted the apps you then press the home key to start using your ipad again. Hope this helps, if it does please give me a rating.
Dec 06, 2011 | Apple iPad 32 GB WiFi Tablet PC
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
Sep 21, 2011 | Canon Office Equipment & Supplies
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
