I am asking for a whirpool washing machine board panel for a version of WWF24ABBPH serial CL4010821 capacity of 10.5 kg if how much is it.
SOURCE: White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Posted on Nov 27, 2008
  • 130 Answers
SOURCE: WASHTUB PROBLEM
Remove top panel. Most of these have front controls, so the screws on the top back allow the whole top to come off easily, remove the screws and pull the cover forward. If the dryer is mounted on top of the washer, remove the dryer off first. Remove the 2 lower screws on the front panel, pull kick panel down and off. Turn off the hot and cold water taps and remove back panel.
2. Loosen two screws that hold weight on back half and slide out weight.
3. Remove drive belt. Cut wire tie, unplug motor and leave wiring in the bottom of the washer. Remove 4 screws/bolts that hold on motor and remove motor
4. On front right, loosen screw and remove rubber drain trap from tub. Squeeze large snap ring and remove water level sensor ( thing that looks like an old fuel filter ) from rubber drain also. Remove little hose from top of water level switch also. ( NOTE: You can also disconnect the level switch hose at the top of the washer. This will make it easier to re-connect, however you'll need to be careful that you do not damage the hose when you remove the tub assembly ).
5. At this point, you might want to remove the motor control board and pump motor assembly. Each is secured by 2 screws and are easily removed. This will prevent accidental damage and give you more room inside the washer to work with. There are 2 connectors on the control board and 1 on the pump motor � be sure to remove those first.
6. Shocks, push the lock tab to allow the pin  to be slid out of the tub and the shock will be free from the drum. ( picture help one and picture help two )Push pins through to the rear and remove. The baskets will now be hanging from the springs.
7. From top, twist out the tube from top of the outer tank. Place support under drum. I use 2 blocks of wood.
8. From front, carefully cut the glued spots where the door seal is glued to the front panel and remove the fill spout holder clip. The tools used is a piece of copper tubing flattened down. I use a wire tie to reinstall as the metal clip can be a pain to work with!
9. Drum should just be hanging from 2 large springs. Remove the clips/spring holders that go over the top of the springs so they can be lifted and removed from the washer. Start on either side, lift spring, move toward center and lower to disconnect drum from the frame. Completely remove spring. Repeat on the other side. Drum should now be sitting on the supports.
10. From above, lift drum and slide out the rear. Leaves you with an empty cabinet.
11. Lay drum on front face on a blanket or sheet and start to remove screws that hold halves together. Once all screws are out, the back half with pulley (top half if sitting on face) easily lifts up from the other half.
12. Remove and replace tub gasket seal. New seal will appear thicker than old one. The old seal can be picked out with a small flat screwdriver.
Assembly.
13.  Place supports in bottom of washer. Lift and slide drum back into place on top of supports.
14. I use a zip/wire tie to go around the water fill tube where the spring clip was and then cut the leftover tail off of the zip/wire tie. I remove the 2 screws holding the plastic hose in place to make installing the wire tie easier. Push the rubber boot over the plastic hose and use the wire tie to secure the boot to the plastic hose. Helps to install drum support springs (big ones on top) first.
15. Install safety clips back over springs. Glue the top hose back into place.
16. Front assembly reverse of disassembly.
17. Back and Motor assemble reverse of disassembly.
18. Finally, pull the boot over the front of washer. Don't do this until drum is in fully, or the boot might not end up on straight and might twist a bit. Small spots are re-glued again in place, super glue works well for this.. Spot glue at the 12 o'clock, 1, 2, 3, 4, 5, 6, 7, 8 and 9 o'clock positions around the opening.
19. Put on back and top.
20. Run load, check for leaks. Note: back panel is structural and should be on for a load to be run.
21. Should be done. Total time 3+ hours. I hope this helps anyone who has to get into the Frigidaire -Kenmore ( 417.###### ) front loader and replace the seal/tub bearing&shell or inner basket.
Posted on May 07, 2009
  • 10865 Answers
SOURCE: Find serial and model number
Hello. for a top loader look here
  • Under the lid
  • On the back of the control panel
  • On the lower-front or side of the main cabinet body
  • Posted on Apr 30, 2010
    • 713 Answers
    SOURCE: Just wondering where I could get a pdf version of
    i have a service manual for that machine. do you need a uses manual or service manual? if you need a service manual please tell me what the fault is maybe i can help. if you need a user manual try ringing your fisher and paykel dealer in your area.
    Posted on May 27, 2010
    • 643 Answers
    SOURCE: manual for ge 10 cycle super capacity plus washing machine frontload
    You can download the manual from this site
    http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=GFDN110ELWW
    Posted on Oct 11, 2012
    Aqualtis washing machine has error code F01 what does this mean?
    F01 Electronic circuit board fault
    Issue: Washing machine is not operating - some or all functions are not selectable.
    Advice: We recommend you disconnect (unplug) the appliance from the mains supply for a minimum of 2 minutes. Reconnect supply and wait 30 seconds and try starting the machine again.
    Jan 14, 2016 | Hotpoint Aqualtis AQXXL129PM Washer Front...
    What is the air pressure for shocks on a 97 flhtc
    I do not know but you could call a Harley Service department or better go there in person and ask.
    Recommended Suspension Air Pressure: FLHX, FLTRX, FLHR/C
    Solo rider up to 150 LB up to 68KG10-20 0 psi0kPa
    Solo rider up to 150-200 LBup to 68-91 KG0-10 psi0-69kPa
    Solo rider up to 200-250LBup to 91-113KG10-20 psi69-138kPa
    Solo rider up to 250-300LBup to 113-136 KG20-30 psi138-206kPa
    Solo rider up to over 300LBup toover 136KG30-50 psi206-345kPa
    Solo rider with capacity luggage of 40 lbs (18 kg) up to 150LB up to 68KG 10-20 psi 69-138kPa
    Solo rider with capacity luggage of 40 lbs (18 kg) up to 150-200 LB up to 68-91 KG 20-30 psi 138-206kPa
    Solo rider with capacity luggage of 40 lbs (18 kg) up to 200-250 LB up to 91-113KG 30-40 psi 206-276kPa
    Solo rider with capacity luggage of 40 lbs (18 kg) up to 250-300LB up to 113-136 40-50 psi 276-345 kPa
    Solo rider with capacity luggage of 40 lbs (18 kg) up to over 300LB up to over 136KG 50 psi 345 kPa
    Rider plus passenger ALLWeights 40-50psi 276-345 kPa
    Maximum GVWR ALL Weights 50psi 345 kPa
    If Tour-Pak is installed, add 5-10 psi (34-69 kPa) to shock pressure.
    Do not exceed 50 psi (345 kPa) suspension pressure.
    Apr 17, 2014 | 2001 Harley Davidson FLHT Electra Glide...
    ADMIRAL 4 SPEED COMBO 10/1 K.G CAPACITY. NOISY ON SPIN
    noise will be drain pump or spin bearings.
    Feb 09, 2013 | Washing Machines
    What is the kg wash ie 6 kg 7 kg or 8kg of the whirpool awm6100/1
    Have a look at the manufacturer's panel, probably on the back- it might give you an indication there- or your manual?
    Another possibility would be to go onto the manufacturer's web site DIRECT to see, OR your (intended) vendor's site?
    If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
    Thanks and good luck!
    John C
    Oct 31, 2011 | Whirlpool AWM6100 Front Load Washer
    To whom it may concern hello I have bosch washing machine was32794 , 1-can I use bleach?may be it damage the machine? 2-how can I distinguish the weight of cloths is more than the capacity of machine?...
    Yes, you can use bleach -- about 1/2 cup oer load -- or more if specified in owner's manual.
    The machine could handle easily one full laundry basket -- see below.
    • Capacity of typical Laundry Basket = 6 kg (dry weight)
    Calculation: [(36 cm x 51 cm x 26 cm) / 28317 cubic cm] x 3.5 kg = 5.9 kg
    Charlie
    Feb 23, 2011 | Bosch Axxis WFL 2060 Front Load Washer
    What's the capacity of a Simpson 175 HD washing machine (approx 22 years old). What new top load should i buy? dials or push button?
    about 6to7 kg.to b honest the machines i find that last the longest r kleenmaid top loaders,maytag top loader,whirpool top loaders,and miele front loaders, i would try to advoid electronic units.nothing will b as robust as your 175.
    Apr 06, 2010 | Washing Machines
    Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
    Washing Machines Logo
    26 people viewed this question
    Top Washing Machines Experts
