Question about Sharp Televison & Video
How to I get on YouTube from my sharp aquos? - Sharp Televison & Video
How do I add youtubetv app to my Sharp 55in P7000 series tv.
Connect your AQUOS LED SMART TV
After about 3 minutes on the video above, it leads you to the SmartCentral app, which should let you add youtube to a Sharp TV.
Getting Started with Sharp SmartCentral
Jan 28, 2018 | Sharp Televison & Video
Sharp Aquos LC60LE632U 60" TV 1080p. LCD HDTV. Great picture. Except, there is one green line, running vertical down the far right of the screen. I'm suspecting that it may be the TCON Board.
I had a similar problem with my Sharp Aquos 60" LED and it was the T-Con Board. Simple to replace and can be purchased in the neighborhood of 40.00. If you have sound and a picture, T-Con Board replacement should be your fix. Great videos on youtube if you need assistance. I would highly recommend that you watch the videos prior to proceeding. I am NOT a TV repairman, just a do-it-your-selfer....
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Mar 31, 2016 | Sharp Televison & Video
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Our Sharp GA864WJSA TV intermittently turns itself off for a few seconds, then turns itself on again. Please help???
Sharp Aquos problem - YouTube
? 1:41
www.youtube.com/watch?v=-EuJZ9NUf3Y
Apr 24, 2012 - Uploaded by rsimon24
So my tv is just turning off by itself, some people tell that is a software issue, others resistance hardware. Has .
Sep 12, 2015 | Sharp Aquos Televison & Video
Why sharp aquos wont turn on
Most likely it's a capacitor fault.
Google "Capacitor bulge" and then search Youtube for your make and model to see if anyone has done an instructional video. You'll need to be comfortable dismantling the TV and be able to use a soldering iron. If this isn't you then take it to a repair shop.
Sep 05, 2014 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Why is my Sharp aquos tv arrow light flashing
This flashing light on the tv is actually a fault code. The 2 most common faults are blown capacitors on the p.c. board which would be visible with the rear cover off, (capacitors generally cost under $1 each) and a blown led which could be replaced but would require the know how. There are youtube videos on this repair but do not recommend this unless you have some electrical background and knowledge. Hope this helps.
Aug 17, 2014 | Sharp LC-46LE835U AQUOS 46 In. 1080p LED...
Sharp aquos lcd26d6usound problem
As far as I know, Sharp covers the repair of the sound problem on your model. Give them a call.
Dec 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
