Question about Canon Office Equipment & Supplies
What cause background on canon ir2200/3300 and dirt on a paper?l3m1
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
I have an error message in Canon IR 5020 "error E000004-0000.. how do I fix it?
Hi.
Power off CANON ir5020 then try to pull-out cartridge toner. check up paper feeder for paper garbage
cleaning using vacuum to get dust and small paper dirt.insert toner cartridge fix and power on again.
if same problem error display.your canon mainboard need repair.
Hope can help you.
Jun 28, 2011 | Canon Computers & Internet
Canon PC921 Replaced toner, bad copies. Is there a separate drum to be replaced?
yes that it 's the most possibillity.
but you must be assure that :
- the paper is not moist. (it makes pale copies)
- the glass has you cleaned up. (it makes black background uneven)
- the transfer unit is not dirty. (it makes black background)
May 21, 2011 | Canon PC-921 Black and White Copier
Paper feeds incorrectly the feeder is pulling to the left and causing the paper to jam or to tear.
Sometimes dried ink on the roller causes it to incorrectly "grip" the paper, making it slip in one section and pull to the side, Check the rollers for Ink and other dirt.
Also try less paper in the feeder, it may simply be too much and is not able to feed it correctly.
Hope this helps GM
Apr 10, 2011 | Canon PIXMA MP470 All-in-One Printer
The paper won't feed right keep pushing it to the left
try to clean the rubber rollers in the paper feeding section. There must be some dirt's or things that causes the roller to slide and set the paper guide properly.
Dec 01, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Canon MX320 series Paper is not feeding straight
either the roller is worn out or dirt, and you may want to replace it or clean it, or you may have some foreign object in the printer that causing it to skew. you can try (CAREFULLY) to flip it up side down and see if anything falls out, other you will need to try the first 2 options.
Sep 16, 2010 | Canon Office Equipment & Supplies
Dark Background on the paper
replace the drum unit (toner) your drum is weak causing dark background
Nov 21, 2009 | HP LaserJet 4 plus Printer
Black lines appear on copies made from top feeder but not from glass top.
Check the paper path from top feeder. Sometimes is a transparent plastic film need to be replace cause a scratch and sometimes is dirt or other obstruction like dust or liquid paper still not dry when scanned a paper and get clogged.
Jun 28, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Copying from Colored Paper
No..The exposure will only give you an overall lighter or darker copy.. Dave UK
Feb 23, 2007 | Canon ImageRunner C-3170U Copier
18 people viewed this question
old marine
old marine
