  • Heating & Co... Master
  • 3,052 Answers
You have picture capabilities... available...
Use them (nobody here is psychic).
There are a world of opportunities ... available to interface control boards with heaters... New & used
You model number does resolve to a REAL HEATER
EVCON FURNACE DGAH056BB5B.. but I have been unable to get it to RESOLVE to any CIRCUIT BOARD NUMBER.
In a case like this you should take
lots of pictures and notes ...
Draw out your schematic...
Get your OWN circuit BOARD number YOURSELF
(from your old board)... It is going to be a HONEYWELL, ROBERTSHAW or a similar manufacturer...
SIMPLY CANNOT BE DONE without you... or a REAL
repair person.
See sample boards...
Posted on Dec 28, 2016
  • 614 Answers
SOURCE: I have an Evcon furnace Model # DGAT075BDF. It
Does your fan work from the on position. New tstat may have RC and RH need to jumper them. If that does not work. Turn on tstat check voltage on board at furnace between w and c if you have voltage you may have a bad board. Also see if there is any reset buttons like on the roll out switches. Smaa red buttons. Push them to reset. Let me know what going on. Rus
Posted on Dec 03, 2009
  • 22 Answers
SOURCE: i have a coleman evcon gas furnace in a 95 trailer
Most Coleman units in a trailer dont have a draft fan. Are you talking about the fan that blows air through the floor registers? If yes, then you will probably need a new fan/limit control. If you do have a draft motor, you would probably need a new circuit board or draft fan relay.
Posted on Jan 21, 2010
  • 3182 Answers
SOURCE: I need to replace a gas furnace thermocouple
HI follow the thermocouple lead back to the gas valve undo the silver nut foloow the lead back to the pilot and undone the nut on thermocouple or it may just pull out , or the burner might have to come out to replace it , if you arenot sure on this then a local gas fitter will do this .
Posted on Jan 26, 2010
  • 3182 Answers
SOURCE: how to replace ignitor on coleman furnac evcon
Hi some of these you do not have to remove the burner you just indo the hot surface ignitor its black with ceramic base ? if so you remove the metal cover over the burner and swap it out .
Posted on Feb 04, 2010
  • 3182 Answers
SOURCE: I have a coleman evcon model dgat070bdf furnace.
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Posted on Feb 05, 2010
Reset button on coleman gas furnace
Reset by turning off thermostat, waiting a minute then turning back on. Turning off the thermostat resets the board.
Feb 09, 2015 | Coleman 7990-319p Evcon Gas Furnace...
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Coleman EVCON GAS FURNACE ugab075bua
Would need to have a serial number to determine.
Oct 13, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Coleman evcon furnace is noisy loud
To many possible answers to this. A description of the noise will help to diagnose the problem.
Jan 28, 2013 | Coleman 7990-319p Evcon Gas Furnace...
How do you replace a pressure switch on a coleman evcon furnace
The pressure switch is mounted with 1/4" or 5/16" self tapping screws and has 2 wires and a rubber tube that attaches to the induced drafts assembly.
Jan 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
Mobile home coleman - evcon furnace model EB23B vandalized. I think what is called the Evaporator coil?? (Copper A shape) was taken from the home. All that remains is the blower. Now...was the copper coil...
What a shame! An a coil runs about $500-$600 and an elec. heater kit about $100 plus labor and if the coils are missing then you Will have to replace refrigerant at $20 per lb.. I would replace the unit for about $1000 and then you'll have warranties on it. Sorry for your misfortune.
Sep 25, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
