Question about Option Computers & Internet
Setting up my Sony Blue Ray, I clicked wired connection. Now I can't find an option to make it wireless. I have already tried to reset to factory settings, it still shows as wired connection.
  • 47 Answers
SOURCE: ntegear wgr614v5
Step One: Reset the Netgear Router.
How To :
Behind the router there is a steel mesh, near the antenna mesh there is a small button insde the mesh by use of a pen you can press that button please disconnect all cables before you commence the procedure and only the power cord to be plugged in. Press the button for 10 Seconcds and then release the button.
Do not connect the internet dsl cable till the congigration is complete.
Step two : Disconnect the power cable for 3-4 seconds and plug it back in.
Step three : plugin the router with your computer/laptop with the help of the cable. use port 1.
Step Four : open the web broweser and type http://www.routerlogin.net/ or http://192.168.1.1/.
Step Five: it would ask you for username and password. enter Username : admin and Password : password .
Step Six : Confiuring the router.
1) please avoid setup wizard and confure it manually and follow the steps below.
2) you would need to click on left frame buttons for the cnigration to come on the right side.
3) in setup section on the right side please click on basic settings and configure as below:
a) Does Your Internet Connection Require A Login?
Answer : No
b) for the next three options its the first choice should be like that from default, if not please set all to automatic.
Then,
Click "Apply"
4) On the right menu now click on wireless settings in the setup section.
a) give a SSID name that is a name you want to see when connecting to the the wireless router while connecting from a wireless device. E.g. ( "mp's netowrk",etc.)
b) set security option as WPA-PSK the third option.
give a password like "abcde12345" should be 10 charactes and alpha-numerical. ( This option is to make your Wi-Fi more secure and to avoid unauthorized access. Key lifetime : 60minutes
then click Click "Apply"
5) Now on the right menu goto advanced tab and click on LAN IP Setup.
a) In LAN Tcp/ip setup change the ip address to : 192.178.1.1 (to avoid dsl ip conflict)
b) there should be a check on use router as DHCP Server.
Starting IP Address 192.178.1.2
Ending IP Address 192.178.1.7
(the ip range should not be more that five ip address as otherwise the performance output would be pathetic)
Then Click "Apply".
Router Config Done..Now on the right side click in "Logout" (bottom most option)
after the router logout is done close the web browser and remove the network cable and the the power cable from the router.
Post Configring Steps :
a) Swich off the dsl modem.
b) plug the dsl cable to the internet jack in the router.
c) plug in the router power cable back to switch on the router.
d) Switch on the DSL Modem.
Wait for 15 Seconds.
Connect to you wireless netowrk using you laptop or wireless card in your computer and provide the WPA-PSK - TKIP passord which you had given in router for preventing unauhorized access.
Bingo !! you are connected...and more secure.
Posted on Mar 16, 2008
SOURCE: Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Posted on Nov 20, 2008
kamal1984
  • 1383 Answers
SOURCE: Can't connect to some websites with wireless router connected.
access your router with folowng link
http://192.168.1.1
or http://192.168.0.1
then type useranme and password as"admin"
or pasword is blank
then check in filter there id blocking of some sites.disable it.then save settigns and restart router.
Posted on Apr 10, 2009
  • 825 Answers
SOURCE: Trying to connect to sony blu-ray wireless where
Certain routers will not have a wps button on it...
You can go for the next options in your bluray...
You will have options to enter network key...(this is wireless network password)
Or you can configure using PIN number...(an 8 digit number printed at the bottom of wireless router)
But if u configured using wps or pin number, then the wireless settings on your router will get sync with bluray player... All your other wireless devices like laptops and iphones and gaming system will lose their connectivity to the wireless router...
so it is advisable to type the security password of your router in bluray player...
Posted on Nov 29, 2010
  • 53 Answers
SOURCE: reset to factory default
The router's admin page is http://192.168.1.1 or http://192.168.0.1 and the default password should be either "admin" or "password" without quotes. There should be a choice under "Setup" called "Factory Reset". That will erase the settings and reset it like new.
Alternatively, you can follow the procedure as given below on all the brands I've tried (Belkin, D-Link, Linksys)
1. hold the reset button for 30 seconds (don't release)
2. unplug the power (still holding reset) for 10 seconds
3. plug power back in (still holding reset)
4. hold reset for another 30 seconds - the lights will usually begin flashing in some odd pattern
5. release the reset button
6. wait 1 full minute or until the lights stop flashing
7. unplug the power for 10 seconds, just to do a reboot
8. verify the settings (e.g. SSID) are back to the defaults
Get instant online Linksys router/wireless router support at http://www.vtechsquad.com/linksys-router-support/ to fix Linksys router/wireless router problems.
Posted on Oct 25, 2012
What does error 1106 indicate?
First please find your PC network settings: Step 1/ : How to check your PC network settings: Using the PC that is already networked to the same network router, please carry out the following procedure. On the PC desktop click Start then click Run now type in cmd and click OK (with Vista/ Windows 7, type Run in the search field located at the bottom left of the desktop and then open Run and type cmd) At the command prompt type ipconfig then press enter/return on the keyboard. The computer will now display setting figures which will look like but not the same as the following examples below. IP Address: 192.168.01 Subnet Mask: 255.255.255.0 Internet Gateway: 192.168.11 Now that the PC network setting figures have been located, the Sony networked product must also be checked to see if the setting figures are the same as those found on your PC. Step 2/ : How to check the Sony product network settings: Using the Remote control press Home/Menu Go to Settings Go to Network press OK Go to Network Set-up press OK Go to View Network Status press OK All the figures shown on the Sony product should match with those on your PC apart from the last 3x figures of the IP Address. The last 3x figures of the IP address sequentially differ due to each networked product having a slightly different IP address, this is normal. Depending on the outcome please see either A/ or B/ below. A/ DO MATCH : PC and Sony product setting figures DO MATCH If the PC and Sony networked product setting figures match but there are still networking issues please do not go to STEP 3 but contact Sony support. Details are listed below and titled Sony Support. B/ DO NOT MATCH : PC and Sony product setting figures DO NOT MATCH If any of the setting figures differ (apart from the IP address as explained above) then that would indicate that there was a problem during the network set up. To resolve this, both the Sony product and router will need to be Reset and the Network set up process started again. Please continue to STEP 3. Step 3/ : How to reset the Sony product and router: Reset the Sony product Using the Remote control press Home/Menu Go to Settings Go to System Settings and press OK Go to General Set-up and press OK Go to Factory Settings and press OK Restore Factory Settings and press YES Once this has been completed turn the TV off at the mains and then switch back on again. Reset the router Usually, press any reset button on the router, or switch off and on at the mains and wait for the lights on the router to settle and become constant. If it is un-clear on how to reset the router, please contact your Internet provider or router manufacturer. Once both products have been reset try the network set up again. Sony Support If there are still networking problems after checking through the procedure above, please contact Sony support with all of the information required as listed below, please call 0844 8466 555 Mon-Fri (9am to 5pm) Sony support will require the following information to help identify any problems that you may have with your network connection. · A full description of the networking problem · IP Address, Subnet Mask, Default Gateway (completed using Auto configure only) · Router make and model · Type of security used WEP or WPA · Wired (cable or Home Plug) or Wireless connection. · What actions have been carried out to help resolve the issue already
Read more: How do u fix error 1106 connecting broadband to sony bravia kdl 32ex520 (no router)? - I have a broadband that i use for my laptop. when i connect to my sony bravia i shows error 1106 and i dont use router to set up anything with router. I connected as a wired connection and cable and ip address is ok but internet connect failed and shows error 1106. Can you please help me out on this :: Ask Me Fast at http://www.askmefast.com/How_do_u_fix_error_1106_connecting_broadband_to_sony_bravia_kdl_32ex520_no_router-qna1013157.html
Oct 31, 2015 | Office Equipment & Supplies
How do I reset my funai blue ray player to factory settings?
Macgo Windows blu-ray Player, with detailed Menu for you operate, and you can reset to factory setting easily. You can try for free.
http://www.macblurayplayer.com/windows-bluray-player.htm
Nov 17, 2014 | Funai Televison & Video
I have internet connection but cannot access internet
Bluetooth connections allow devices to connect without the use of wires or cables.
Some users of the Sony Vaio laptop computer have encountered problems with the connection of Bluetooth devices with their computer.
The problem lies with turning on the Vaio's Bluetooth function.
This is turned on through the computer's Wireless Switch Settings manager.
The icon for this is in the system tray in the taskbar when the computer is first purchased.
Double-click the "Wireless Switch Settings" icon in the system tray of the taskbar.
It is a a blue-green icon with "LAN" in one corner and "B" in the other.
Check the "Enable Bluetooth Device" setting in the Bluetooth Device section.
Click "OK."
If the device was already enabled, change the wireless LAN from "2.4GHz" to "5GHz" because, as the warning message should say, using the 2.4GHz wireless LAN and the Bluetooth device can make the connection unstable.
Click the "Apply" button after the appropriate boxes are checked to activate the Bluetooth signal. A blue light should come on near the computer's on/off switch for the Wi-Fi radio.
Click "OK." Another dialog box should appear explaining that the Wireless Switch Settings icon should now be in the taskbar.
Use this icon if you need to turn off or on the Bluetooth device in the future.
http://supportforsony.iyogi.com/vaio-f-series/bluetooth-4.html
sony support
Apr 15, 2014 | Sony Vaio Tap 20
Wont play Blue Ray but will play regular DVDs
If unit does this with all blue ray disks,old and new ones, then the unit is defective. Period
Router has nothing to do with the playback of a disk!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sep 15, 2017 | Sony BDP-S350 Blu-Ray Player
Sony bluray player wont get netflix option
are you able to get wifi in that room?it sounds like youve lost connection between your network and the bluray,look in your owners manual for sony bluray and follow steps to connect to wifi.if you dont have your manual try this link.http://tv.manualsonline.com/manuals/mfg/sony/bdps350.html
Nov 27, 2013 | Sony BDP-S350 Blu-Ray Player
Error_model_bind samsung
Try different network cable and check. check if the Samsung HT-E5400 Blu Ray Home Theater [HT-E5400] has a reset option and reset it.
Try the following link for instruction:
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?from_osc=&homeid=642763&idx=410781&modelcode=&modelname=HT-E5400&
Jan 27, 2018 | Samsung HT-E5400 Blu Ray Home Theater...
I just put a pc in my room and got a wireless router because i have a pc in my living room already hooked up to the internet. i tried to hook up the wireless router and get a connect but now the my pc...
try to check the the network cable.there is something wrong in your cable.maybe wrong setting of wires.but you said you got wireless router right.why go on wireless..much better you buy a wireless USB connector.less maintenance.if you prepared wired..this is the setting of pins of network cable.8 pins each RJ45 both ends. 1.stripe orange 2.orange
3.stripe green 4.blue 5.stripe blue 6.green 7.stripe brown 8.brown
Jul 15, 2011 | Computers & Internet
My new rca blue-ray dvd player model RTB 1013 will not receive Netflix instant streaming. when I click netflix it says testing connection then says connection to 0.0.0.0 successfully established. then it...
I Bought a RTB1013 300W Blu-ray Home Theater and I noticed under network setting the was a wireless option but it will not let me pick it. What is up with that and how can I make it work?
Dec 21, 2010 | RCA Audio Players & Recorders
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
Connectivety
Usually the default password is admin with no username . If that didnt work , the only option you can do is reset the unit to factory default.
It will reset your password but also reset your router to factory settings. You will need to setup again your router to connect to the internet.
Cheers,
KJ
Jun 30, 2010 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
Top Option Computers & Internet Experts
D. E. Hev
Steven Conroy
Steven Conroy
Are you an Option Computer and Internet Expert? Answer questions, earn points and help others
