Question about Crock Pots & Slow Cookers
I havee a rival2quart slow cooker with high,low,and warm settings removable pot mijoteuse 1.9litres no instructions in the box Where do I obtain instructions and recipes ?
  • 3 Answers
SOURCE: Slow Cooker
Bravetti is made by EuroPro:
Phone: 1-800-361-4639 or
1-800-798-7398
Good luck.
Posted on Mar 13, 2008
  • 4 Answers
SOURCE: Rival 38651-C 6-Quart Slow Cooker
I is low setting and II is high
Posted on Nov 02, 2008
  • 173 Answers
SOURCE: Not sure high or low on the Ronson slow cooker
2 is high.
Posted on Jul 08, 2009
  • 97 Answers
SOURCE: slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Posted on Mar 06, 2010
SOURCE: I have Ronson slow
I also have a Ronson slow cooker.
Instructions from the book read as follows:
- On setting 1 (low), the slow cooker can operate all day and night if required.
- When set to 2 (high), it is very much like a covered pot on the stove. Foods will cook in half the time required for 1 (low).
- When set to auto, the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature, then switches to 1 (low) and maintains a constant slow cooking temperature. Auto is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
I always use the auto setting, unless I don't have as much time, and will then use setting 2.
Posted on Sep 19, 2010
I have four settings on my Crock-pot slow cooker, what do they mean?
From left to right, the settings are as follows:
OFF LOW HIGH KEEP WARM.
Nov 09, 2017 | Crock Pots & Slow Cookers
I need an owners manual for the SCVC651
I couldn't find the specific manual for this, but I did find some basic instructions on a personal review:
"Rival calls this a SmartPot and describes this unit as "programmable". All this really means is that you can program the slow cooker to cook either on "High" or "Low" for up to 20 hours, in 30 minute increments and then it will automatically switch to the "Keep Warm" setting and keep your meal warm for hours. You cannot program multiple steps, such as going from the "High" to the "Low" setting. The red, LCD clearly displays the remaining cook time.
Simply plug in the slow cooker, and then push the clearly marked buttons (with a pleasant, audible tone) to move from "Low" to "High" to "Keep warm" settings. Then push the Timer Button to set the desired cook time."
Hopefully, this helps answer your questions!
Nov 23, 2010 | Rival SCVC651-F Slow Cooker
I have Ronson slow cooker with no manual, it has settings 1,2 qnd auto. Which is high and low, and what does auto setting do>
Sep 15, 2010 | Crock Pots & Slow Cookers
Slow cooker will only stay on warm. How do I put
Feb 11, 2010 | CorningWare SC60 Slow Cooker
When you set the cook time it goes to warm will it change after it warms up
with this slow cooker it is automatic for temp settings you set the time and the rest is automatic, 1-6 ohurs starts on low and 7 and above start on high it worked out great
Nov 06, 2009 | CorningWare K4903 Slow Cooker
Rival 7 qt slow cooker
O-is OFF I= is low II= is high WARM= is real low or keep warm
Aug 28, 2008 | Rival 5070 7-Quart
Corningware slow cooker 6qt
If you choose the auto selection the slow cooker will cook for three hours on high then will automatically reduce to the low setting.
Aug 22, 2008 | Crock Pots & Slow Cookers
Older model General Electric crock pot
The auto button is ususally it startts off on high setting to warm up the crock and when it reaches a pre set temperature it will shift to med or low which ever is the next lower setting it will continue cooking at this setting unless you change it
Dec 31, 2007 | Crock Pots & Slow Cookers
Crock Pots & Slow Cookers Logo
50 people viewed this question
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
