Line 1 red light on. How do I turn it off? - Televison & Video
How to turn off red blinking light
CUSTOMER CARE LINE IS:
1-817-858-2929 OR
1-800-297-1023
Jan 02, 2015 | Uniden DECT 6.0 Cordless Telephone...
Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Lee
Jun 17, 2008 | GE RCA 4-Line Speakerphone
Red light laser doesnt come on anymore
Same thing happened to me today (after 1 day of working). I called the toll free customer service line 1-888-726-6369, told them what happened, they asked for the manufactured month (printed on sticker on back of unit, mine wash March 2012), and will be sending a replacement unit via fedex. Try it!
Oct 21, 2012 | FroliCat BOLT Laser Cat Toy
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
My 3 year old "Smart Water" heater will not turn on. No hot water
It sounds like there is air in the line, so open the gas line just a little for a few short seconds to let some gas out, after that, keep the one red dial on pilot then turn the other to about medium. Light the pilot by depressing the red button, then once the pilot is lite, continue to hold the red button for about 1 minute, Once that is done slowly release the button and then turn the dial that is set to pilot to on position and give it about 1 hour to heat up
May 08, 2010 | General Electric GE SmartWater Household...
Computor doesnt connect to internet states a local network cable is unplugged 4 green lights on routerand one red light turn off all power and unplugged cable also reset button but no internet connection...
If the red light is your DSL light it means you have a line fault or no internet connection. Contact your provider
If the red light is your broadband / internet light - it means you are not logged on properly. Chck your username and password are correct - especially after the reset!
Oct 06, 2009 | Belkin (F5D5231-4) Router
Line 2 button light blinking, can't clear (and I have no line 2?)
Ok, i just figured this out a few min after posting the similar question. Reconnect your phone line to the data port and reselect the line one or line two selector swith position until the light goes out. I removed the phone from the wall to paint an must have accidently moved the switch. If the switch and the input port are out of sync you will get a red light on line one or two. Good luck!
Mar 13, 2009 | RCA ViSYS 2-Line Speakerphone
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Light comes on
First, it is normal for the line 1 light to quickly flash once every hour or so while it scans all of the phones. If the light is staying on though then this is a problem.
Look at all of the phones. All will show a RED light except for one that will have a GREEN light lit up for line 1. The green lighted on line 1 means that this is the phone that believes it has the right to use the line. When one phone uses the line all of the others are given a signal through a sub carrier of line one to light up in the color red.
I would suspect that the problem phone is a wall phone unit. This is because the switch on this phone is fighting the weight of the receiver versus gravity. There is not much tolerance in these switches as you will notice if you gently put your finger on the receiver at the top of a wall hanging phone.
If it is a wall phone unit causing this problem you can do 1 of 3 things.
1- you can switch this phone to a desktop so gravity is not working against you but for you.
2 - you can put an ugly looking spacer on the button so it pushes in farther.
3- you can try to perform inside surgery on the phone to adjust the tension of the spring on this button.
Jul 05, 2008 | GE 29488GE2 Corded Phone
On line/error light
The online/red light would only come on if:
1. there is no paper;
2. missing communication (USB) with the PC;
3. the front door is only partially closed ;
4. if the toner/cartridge is not fully engaged and locked in place; and
5. internal printer error(s).
More often, it is either the door or the toner that causes this.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Feb 10, 2008 | Samsung ML 2010 Laser Printer
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
