Question about Dell Computers & Internet
DEll latuide E6320,its Freezed when i keep for long time not working , Goes to sleep mode
If i use for long time its works very well, but i i keep for sleep mode and come to back again its freezed need restart to work again well. any idea please to fix this issue?
    Top Expert:
  • Dell Master
  • 26,180 Answers
Right click on the battery icon and choose power options (depending on OS, it may be called something else) to change the timing.
Posted on Dec 28, 2016
Came home to find computer off. It was left in sleep mode. The moniter keeps saying there is no signal and the keyboard has no power.
If its truely in sleep mode, and won't come out of sleep mode. Unplug the computer from its power, hold the power button down for 5-15 sec, then wait 2-5 full minutes. Then plug it back in, and turn it on.
If that doesn't work it is NOT stuck in sleep mode. Most dell computers I've worked with the caps go out in the power supply and/or the motherboard. I would next clean out the computer with canned air, check the caps on the motherboard, and in the power supply. If there are any bad caps, replace them, and it should fix it. Hopefully though the above paragraph fixes your problem.
Sep 13, 2013 | Dell Dimension 4600 PC Desktop
Dell inspiron 1545 goes to sleep while in use
The solutn is...please uninstall..the AHCL driver from ur pc..then the problm is solve...try it...thank u..
Mar 26, 2013 | Dell Inspiron 1545 Notebook
Jumper reset dell e6320
Dell Latudude E6320 solution
the best way to fix the bios password is to open the laptop.
remove all screws from the bottom flip it over
around you keybord is an plastic square remove the ring and remove the
keybord and all the screws open the upper case .in the leftcorner you see
an clatcable from you hdd remove that cable. go little to the right from there
and up you see the atmel 11131 cmos chip 8 legs.
solder on leg 3 and 6 an wire and if laptop boot up shotcut the wires tap tap tap if the password is still there remove the wires and solder 1 wire on leg 4 and 5 and do the same if password is still not removed final option is
leg 3 and 7 keep note that you tap the wires if system boots up.
on the cmos is an small hole the starts pin 1 don't forget that
fom hole
8 7 6 5
1 2 3 4
number 1 =where the smallround hole is!!!!!!!!!!!!!!!!
Apr 02, 2012 | Dell Latitude E6320 Laptop Computer 250 GB...
My Dell Monitor keeps going into sleep mode immediately after booting up.
Make sure your computer's screen resolution is fine for that when you power up the computer press F8 key 5 to 6 time untill you can see safe mode and other menu if you are able to see safe mode then enter in enable vga mode then enter as admnistrator go to control panel->display property ->settings change screen resolution to 1024*768 then apply and restart it.Let me know if you need further assistance.Thanks for using FixYa.
Aug 03, 2011 | Dell Dimension 4600 PC Desktop
Hi ,My dell screen goes to sleep mode after a long wait of not being used, say an hour, ..............but the pc sleep is not set ? The message comes up to move mouse ,or press any key ,but this does not...
please check your monitor settings may be sleep time is defined there. secondly check your system sleep time again. and also check window power saving mode. may be your system goes to power saving mode.
If you like this rate me kindly
Oct 12, 2010 | Dell E153FP 15" LCD Monitor
Monitor works fine until the sleep mode and then it goes blank. I have to unplug the power button and it does work again
It seems it is a motherboard battery problem. It most likely is not the monitor which is in "sleep mode", it is the computer itself.
When you cannot get a computer out of "sleep mode" by any other means, typically the cause is that the button-cell-type battery of your computer, which is located on the motherboard, is empty. When your computer detects this battery is empty, it goes into a low-power mode. The solution is to replace the button-cell battery on the motherboard of your computer
If this solution works fine for you please rate this
Feb 24, 2010 | Dell E196FP 19" LCD Monitor
Computer goes to sleep before it even starts up
Hi there, it appears as though the Power Options are set too short a time and the PC is going into sleep mode. Go to Start menu/Control Panel and look for Power options. Set them all to "never" This will prevent her PC from going into sleep mode. Good Luck.
Oct 26, 2009 | Dell Dimension 4600 PC Desktop
Sleep problem
I've seen this on many Dell machines, and I've found no real fix for this. It seems that this function either works or it doesn't. You can do a restore back to a point that you remember it working properly, but eventually it will start doing it again. I've decided that this is a glitch with Dell's systems. You can also do a bios update from Dell's support site, sometimes this helps with the little glitch they pick up.
Jul 01, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
Alun Cox
