Question about Sony Audio Players & Recorders
I need the codes for my sony surround sound - Sony Audio Players & Recorders
How t0 make sound work on older sony surround sound sanyo tv icannt get sound through surround that a older sony
Make and model of each device is needed to assist you. The Sanyo TV will need audio out that is support by an audio in on the Sony.
You then need to know how to enable sound to move from the TV to the Sony. This could be a physical switch or an option in the TV's menu.
Finally you nee to change input on the Sony to the TV. This is likely an input button that matches the name on the input connector you used.
Jul 11, 2017 | Sony Audio Players & Recorders
Hi there I'm trying to connect my technics
are you trying to use the speaker system on your tv? or are you trying to get sound from your tv to your surround system?
you will need audio patch cables!
sound from your tv to surround:
line out on tv to line in on surround
sound from your surround to your tv:
line out on your surround to line in on your tv
Aug 22, 2011 | Sony Televison & Video
Need to know is there is a input on the back of the sony davdx255 for the tv to recieve surround sound.
Does a TV NEED surround sound if you have a surround sound HIFI? Normal setero sound would probably suffice as the TV might not actually have electroics or speakers to do anything but mic\x it down to lo-fi stereo.
Correlary: You COULD just drag regular RCA audio out of your cable box to the TV if you want to watch the news or talk shows.
Jan 30, 2011 | Sony DAV-DX255 System
Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Aug 21, 2009 | Audio Players & Recorders
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
Surround sound hookup question?
It looks like all you'll need to do is hook up audio out from DirecTV to audio in on the surround sound system. Sony has an interesting hookup recommendation guide on the product support site:
That should give you the connection options. The short answer, though, is to connect the best audio out from DirecTV to an audio in on the surround sound and then choose that option in the surround sound system when you want to watch TV.
Jul 16, 2008 | Sony DAV-X1 System
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
42 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
