Question about Pool & Spa
Lazy-spa hot tub saysE03 what to do - Pool & Spa
  • 34 Answers
E.0.3. The pump’s thermometer reads the water temperature below 4°C (40°F)
1. The water temperature is lower than 4°C (40°F). 1. The spa is not designed to operate with water temperatures lower than 4?C (40°F). Please unplug the pump and move to a warmer ambient temperature. The pump should only be restarted when the water temperature reaches 6°C (43°F).
Posted on Dec 28, 2016
Lay-Z-Spa e01 error
E01 error code. Drained hot tub, unhooked green egg. Ran hose into the two filter pipes and back flushed the pump. Plugged back in and it works fine now.
Jun 02, 2017 | Pool & Spa
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
What is the best product to remove ring in hot tub?
SECRET:
Use a a Good Quality Name Brand "Filter Cleaner".
Works great as a surface cleaner for your hot tub.
May 26, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Is there a good website to buy accessories for my hot tub? steps, cover lifter, etc?
i like the brand litehouse. you can see their spa accessories here:
http://www.litehouse.com/spa-accessories.aspx
Jan 28, 2013 | Pool & Spa
Lazy z spa error e05
You can find almost every error code known out there for hot tubs at the following link: Error Codes
Click on that link and then scroll down through them.
Rod
US Parts Center
Aug 26, 2012 | Jacuzzi Pool & Spa
My hot tub doesn't heat up all the way even though it says it's ready
If a floating thermometer is more than 3-4 Degrees F off what the control panel display temperature then the temperature sensor has likely failed.
Jul 17, 2012 | Pool & Spa
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
Jan 06, 2012 | Endless Summer Pool & Spa
Hot tub has power but nothing else works
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
Oct 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hot tub wont stay hot
Contact Maryland Hot Tub Repair - Pool and Spa Service and set up a Diagnostic service call. Here is there contact info: Maryland Hot Tub Repair - Maryland Pool Service - Maryland Spa Repair Pool Parts - Spa Parts - Hot Tub , Pool and Spa Repair - Pool Opening - Pool Closing - Pool Service 410-304-2463 http://www.maryland-hottub-pool-spa-repa... or see them on http://marylandhottubrepair.blogspot.com...
May 20, 2009 | Jacuzzi DX50-959 Elara 7242 Salon Spa...
Pool & Spa Logo
100 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
