Question about Pool & Spa
Need to no what to do when E03 shows up on Lazy - spa hot tub
  • 246 Answers
SOURCE: our heater show's Eo4 never gets hot
lol but u never clean t burners
Posted on Sep 14, 2009
  • 366 Answers
SOURCE: How do you replace a flow switch in a spa, or hot tub
turn off the power to the spa. remove the cabinet under the topside remote to expose the equipment compartment. You should see the flow switch, it's usually a threaded 3/4" plug with a single grey wire coming out of it. Most of them are threaded into a tee or a special transparent fitting. If the water level in the spa is above the flow switch, you may have to drain the spa down unless you're very fast about getting the new switch in. Unthread the old switch and thread the new one in. Follow the wire on the old one to the spa pack. You'll have to remove the screws on the cover to expose the circuit board. Follow that wire into the spa pack to see where on the circuit board that it is plugged in. It may be good to run the new wire to have in place as soon as you unplug the old one you can install the new one with no question as to where it plugs in.
Reinstall the cover on the spa-pack and turn the main power back on. Make sure that the arrows on the new flow switch are facing the correct direction (direction of flow). Once you have the spa on and it starts back up, run everything to check for leaks and proper operation. If the flow switch was the only problem, all your faults should be cleared and you should be in good shape. If there are no leaks, you can reinstall the cabinet panel.
The new switch should already have teflon tape on the threads, if not, use teflon tape, apply the tape in the direction as if you were threading a nut onto the threads. You only need a few wraps of teflon tape, too much can crack the fitting you threat the new flow switch in to.
Posted on Nov 07, 2009
  • 366 Answers
SOURCE: our artic spa hot-tub is showing HL in the panel
HL is normally a "high limit" fault. If your filter is clean and you have sufficient flow, you may have a faulty high limit sensor. It should be mounted on the heater itself. The high limit sensor shuts the heater off if it senses excessively hot water. Check to see that you have sufficient flow, clean the filter, and make sure the filter pump is running. If everything else is running properly, you may have to replace the high limit sensor.
Posted on Dec 28, 2009
jharwell668
  • 640 Answers
SOURCE: want to hook it up to my hot tub
Yes, these pool heaters are designed for use with a spa. They are made to accommodate temperatures for both a pool and a spa running off of the same heater. Check the owners manual for specific instructions.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Posted on Aug 19, 2010
SOURCE: i have a lazy xl spa heater light coming on
when the bubbles are on the water blowing out of them is cold, you can not run bubbles and heat at the same time
Posted on Oct 19, 2010
My Vegas hot tub keeps showing eo3 can you give me some advice please
looks like it's got a bad thermister or thermostat
E03 The pump's thermometer reads the water temperature below 4°C (40°F)
1. The water temperature is lower than 4°C (40°F).1. The spa is not designed to operate with water temperatures lower than 4?C (40°F). Please unplug the pump and move to a warmer ambient temperature. The pump should only be restarted when the water temperature reaches 6°C (43°F).
» 2. The pump's thermometer is broken.
Hot Tub Ireland
Feb 24, 2018 | Pool & Spa
Lay-Z-Spa e01 error
E01 error code. Drained hot tub, unhooked green egg. Ran hose into the two filter pipes and back flushed the pump. Plugged back in and it works fine now.
Jun 02, 2017 | Pool & Spa
Lazy-spa hot tub saysE03 what to do
E.0.3. The pump’s thermometer reads the water temperature below 4°C (40°F)
1. The water temperature is lower than 4°C (40°F). 1. The spa is not designed to operate with water temperatures lower than 4?C (40°F). Please unplug the pump and move to a warmer ambient temperature. The pump should only be restarted when the water temperature reaches 6°C (43°F).
Dec 28, 2016 | Pool & Spa
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
There is a leak and we can not find it. Any solutions
This may help?
Fill spa to highest level possible.
Heat to 100 degrees or higher.
Then, with your bare hand feel throughout the bottom rim and anywhere else you are able to: see if you can feel "Warm/Hot" water. Any "Cold" water is not the area of the leak, that water has "Travelled" there. The warmer the water, the closer you are to the origin.
Jan 01, 2014 | Eclipse 4 Person Hot Tub Spa - Dream Maker...
Error codes
Here is a link showing the most common error codes for hot tubs using Balboa Instrument spa packs.
Balboa Direct Factory Direct Balboa Water Group Bath and Spa...
Rod
US Parts Center
Nov 16, 2013 | Qca Spas Majestic Series Aruba Xl Hot Tub
Lazy z spa error e05
You can find almost every error code known out there for hot tubs at the following link: Error Codes
Click on that link and then scroll down through them.
Rod
US Parts Center
Aug 26, 2012 | Jacuzzi Pool & Spa
Pool & Spa Logo
661 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
