Question about Stihl Garden
I need a choke lever for a Stihl 015 AV chainsaw. Could you tell me where I might find one?
  • 22 Answers
Many parts for these saws are obsolete due to age. If not available at local Stihl dealer check online for Ron's saw shop. He does a lot of obsolete parts.
Posted on Dec 28, 2016
Instruction on how to start a stihl chainsaw model 014 AV
this is a picture of a 014
looks basic..older model .. no safety features
starting all depends on
carby idle hi /low set correctly
air filter clean
clean fuel....fuel /oil mix
good spark
new spark plug if required
chain oil in oilier section
correct chain tension on the cutting bar
being a two stroke
and the engine has good compression
crank casing seals are in good condition
never have your body in line with the chain
it could run off the bar at startup ..flick .onto your arm or face
choke on
trigger lock on
hold the handle and pull cord handle ..firmly
let the weight of the chainsaw start itself
let the chainsaw go downwards till motor splutters
choke off
trigger lock on
drop the chainsaw downwards a few more times
and it should start
other way is put foot in the foot plate of the handle
and start sequence is the same
if not something is out of adjustment or needs servicing
Oct 14, 2016 | Stihl Garden
How can I obtain a copy of the stihl schematics for the Stihl arborsaw 015
Stihl, like most makes, is online. Go to Stihl site and search for your model.
Aug 18, 2014 | Garden
I need astihl 068 chainsaw choke lever
L&S engineers have your part. The part number you quote here is for the stihl cylinder kit. go to this link
Jan 21, 2014 | Stihl Cylinder Assembly for 11110201200 /...
Stihl fs 86
I am a Stihl mechanic. We tell all our customers that the proper starting procedure for a Stihl is as follows. Turn on the switch. Set the choke lever to full choke. Prime the primer bulb three times(if it has one) and pull the pull rope NO MORE THAN THREE TIMES with the choke on. If the unit has not tried to start after the third pull, open the choke lever and pull till it starts. Sthil carburetors are notorious for flooding after pulling the rope more than three times on choke.
Oct 08, 2013 | Garden
How to remove the clutch assembly on a stihl 015 AV
Remove spark plug.
Use a piston block to stop the piston rising.
Remove the chain sproclet cover.
Turn the clutch with a socket clockwise to undo.
Dec 11, 2012 | Stihl Chainsaw Hedge Trimmer Clutch 015 Av...
Starting procedure for stihl 012 av
Full choke, stop switch on run. Pull rope handle 3-4 times or more until it "tries to start" (it will not start, but it will try to for a split second) move the choke lever to the half-choke position and without pulling the throttle, poll the rope handle until the engine fires and runs for 4-5 seconds then fully open the choke to the run position, let it warm up for 25-30 seconds (don't forget to let it cool down about 45-60 seconds before you turn it off!) and then proceed to use it.
Aug 07, 2012 | Stihl Garden
How do you choke carb. for cold start
The choke is built in to the master control lever on the left side. Squeeze the throttle triggerand push the master control lever all the way down. That is choke position.
get a free stihl manual shipped to you at
Oct 11, 2010 | Stihl MS 290 Chain Saw include 20" 50cm...
Need a diogram of how the choke on a 026 stihl chainsaw in setup.
the choke is operated by the fingers on the handle grip...the lever is stop...on...choke...when motor running just flick back up to run mode...the choke butterfly is just a open or closed position in the carb y.
Jul 21, 2010 | Stihl 18" Chain Saw Bar 3005 008 4717
My Stihl 015AV leaks oil from the oil pump area. Any ideas? I've examined the pump, the gasket and the case and cannot determine the actual source of the leak.
This is an international collection of chainsaw enthusiasts with a few 2-cycle mechanics thrown in for good measure. Chainsaw thread (free to join)
This thread is discussing an oil leak on a Stihl 015; join in.
Jan 16, 2010 | Garden
Garden Logo
187 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
