Question about Yamaha Audio Players & Recorders
Video stopped working on Yamaha rx377. It works when I plug hdmi from cable box to projector.
simplemitch
  • 752 Answers
SOURCE: No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Posted on Dec 04, 2007
  • 14 Answers
SOURCE: bose 38 with a Scientific Atlanta 8300 HD DVR and Epson Projector
The Bose VS2 does not pass the HDMI audio. Must connect analog or digital audio direct to the corresponding audio input on the media center. Also, verify you have loaded laster Console Software revision provided by Bose.
Posted on Jan 26, 2008
Drummernick
  • 440 Answers
SOURCE: No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
Posted on Feb 10, 2008
  • 7 Answers
SOURCE: My PS3 hdmi cable does not work
First off, if you want to use the hdmi remove the supplied composite cable from the back of the ps3.
You don't need both plugged in at the same time, and I'm not sure with the ps3 but some video devices will not enable both at once.
Have your tv selected for whatever hdmi input you have it plugged into. They should be labeled where you plug them in.
With the unit in standby, switch off and red light in front, hold the power button by the disc tray for 3-5 second. You will hear it beep, after the initial turn on beep, then you should see a display set up screen.
If you switch back to the composite, you will have to do this over again.
Posted on Jul 06, 2009
  • 127 Answers
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Posted on Mar 02, 2010
How to pass video through the receiver
the cable hdmi to rca does not work it is a scam. b option will work but cost a lot of money. if your receiver has an rca out that should work to your projector not sure about the in and output mode to do that from your receiver
Mar 25, 2014 | Yamaha HTR-5063 Receiver
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
I have a yamaha home theater and the front screen says decoder off what does that mean?
The Yamaha is not getting a PCM (digital surround sound) audio stream. This happens when I turn off the cable box. It also happens when I plug the HDMI output to a projector or monitor that is not HDCP compliant. I can't use an HDMI to DVI adapter.
Nov 27, 2010 | Yamaha HTR-5140 Receiver
I plugged in my cable HDMI into my RX - V365 Yamaha reciever. and HDMI into my TV. I get video, but cannot get my attached (to reciever) speakers to play. Help
RX-V365 doesn't support HDMI audio. You need to connect the cable box also via spdif cable for audio to work. Look at the box if it uses optical spdif or coax spdif. If optical, you see that optical input on receiver is named DTV/CATV, so use also DTV HDMI for video. Coax spdif is named DVD, so in this case you will need to use DVD HDMI input.
Also you need to configure the inputs accordingly.
Nov 14, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
No video from RX-V863
This reciever might not upconvert component or composite to hdmi, which means if you have anything but hdmi hooked up you will not see it. Check your manual for what all the reciver will ouput.
Jul 24, 2009 | Yamaha RX-V863 Receiver
Jun 05, 2009 | Yamaha RX-V463 Receiver
Lose audio unless projector is on or unplugging hdmi cable from sharp xr-32x projector. works fine when watching projector
Your receiver is sensing the video source. Try using optical, or coaxial digital audio for an input, this may work.
May 11, 2009 | Yamaha HTR-6160 Receiver
Hdmi connection problem
it does do dvi-d for computer, but does not handle high-definition video. it does not have the same resolution.
Mar 14, 2009 | InFocus Proxima DP6155 Multimedia...
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
