I RESET CABLE BOX. NOTHING HAPPENED - Televison & Video
Sanyo LCD Model # DP46819, having sound issues.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jun 01, 2016 | Sanyo Televison & Video
Aig No siginal
Hi THERE,
I WOULD LIKE TO KNOW THE MODEL# AND THE MAKER OF YOUR UNIT..
HAVE YOU TRY TO WATCH ON THE TV IN THE VIDEO MODE?
KEEP ME UPDATED ON HERE.
Sep 30, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Philips 42plf7422 RANDOMLY SWITCHES INPUTS
There is nothing wrong with the TV I assumes. Have you tested it a hard reset? If not do a hard reset and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. An overnight unplug will be more effective. This must make the TV to a hard reset. If it do not help you, you have to enter its service mode options to make it a factory reset. If you wish to get more details about how to enter the factory mode check this link. http://electronicshelponline.blogspot.com/ Service mode and alignments to many brand TVs, including Philips models, have been discussed in detail there with illustrations. Pull up older posts there, and surf the site with patience.
May 29, 2013 | Philips 42PFL7422D 42 in. LCD TV
Need cable tv for sony trinitron bbe
have you been select ' cable ' at the settings of your tv. then where did you hooked up the cable box at the tv ?.have you been tried to reset the cable box.
Dec 04, 2012 | Televison & Video
My Motorola dct700 is turning on and showing the guide page but says channel should come on soon had been this way all day, nothing wrong with the cable trying to get it on rather than waiting for tech. I...
This only happens under 2 conditions. 1) you are not getting signal or 2) the box is bad. Now if you have cable in the rest of the house it could be a glitch with that box. Sometimes the box doesn't communicate to the cable co or vice versa. By resetting I'm assuming you disconnected power from the wall and waited over a minute. A call to the cable co will be needed to resend a signal over the line to activate it. Some cable co can even do this by an automated system. If the box is bad, well you gotta call them anyway.
Apr 08, 2011 | Arris DCT700 DTV Receiver
Have pioneer pro-950 hd plasma tv. Has been working great. turned on this evening and got a display saying Plasma Display - starting up. please wait. nothing happens? can't find anything in the manual...
Tries unplug,replug both tv and cable box an hour later.Let the tv reset it self back to the factory setting.The cable box to upgrade it softwares.The tv now should,work again.
Oct 20, 2010 | Pioneer Elite PRO-950HD 42 in. Plasma...
MY DUAL XDVD700 WONT POWER UP BUT COMES ON WHEN I PRESS EJECT....
look at ur axelary fuse in ur car fuse box and see if its burned and if it is u have a short somewere in ur deck. check ur fuses
Jun 27, 2009 | Car Audio & Video
Channel number display won't turn off
This is a common problem with some cable boxes. Most likely it is not the television. Try to unplug the cable box for about five minutes to allow it to reset. When the cable box reboots it should reset itself. Plug the cable box back in and see if the number is still stuck on the television.
Nov 13, 2008 | Samsung LN-T4671F 46 in. LCD Television
Green and purple ghosts
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Oct 09, 2008 | Panasonic PT-47X54 47" Rear Projection...
Green Screen
Turn Tv off by power point unplug even for 30 or 45 minutes then turn back on. that way the tv has time to reset back to normal
Sep 07, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
