Question about Garden
How do you get the left side controller on a wild thing to go forward
Left controller will not make wild thing go forward
SOURCE: sony KP-53XBR45 convergence
Hey, found the problem. Your Convergence IC chip went bad. Buy one at Bluestar International Components (bluestar-online.com) - order part number STK392-010 for 6.99. I've read that there are two in the system and replacing them both at same time is a good idea...so, order 2. Now, if you are handy, it will require you to open the back of the TV and solder out the old chip and replace with new. If not, then you might as well call a TV repair person and have them fix. However, every place I've called works on a minimum fee for "large screen TVs" - the cheapest I could find in Atlanta was $399 minimum service fee. So, I'm going to risk the home sodering job .... it's a 10 year old TV and as good as it's been to me, if I screw it up, I feel I've gotten my money out of it. Good luck with your repair. My parts are on order.
Posted on Oct 26, 2008
  • 67 Answers
SOURCE: I have a new troy built lawn tractor with 7
Its under warranty call for service, they may even come to you.
Posted on Sep 24, 2009
Testimonial: "In process as we speak. Nice web site."
gewiz
  • 1271 Answers
SOURCE: user needs to use left hand for forward and reverse and would like wires switched
hi, you need to expose the throttle pot that is the pot attached to the lever you move to go forward or backwards, normally it a top cover known as the tiller cover, once you done that you see the throttle pot has three legs with coloured wires attached now you need to crossover the outside wires, not the centre one, by doing this you're are moving the reserve to the right hand side and the forward to the left hand side.
if you require more assistance then please let me know..
that's it,
regards
please give me feedback
Posted on Dec 18, 2012
SOURCE: Left motion arm in need of adjustment
You don't adjust it yourself, contact Authorized Service Station and they'll adjust it for you.
Posted on Apr 26, 2014
claudeinmo
  • 9098 Answers
SOURCE: replace left side rear suspension
The move indicates a torn attachment, even replacing the bracket
may not be helpful.
Posted on Sep 01, 2015
Can't find where to put batteries in for lights
The battery compartment is on the back side of the headlight underneath the right turn signal button. Just look beside the forward reverse switch and down you will see the compartment. you have to turn the handlebars all the way to the left.
Apr 02, 2014 | Lil' Rider tm Harley Style Wild Child...
Blade MQX QUAD-COPTER
It's difficult to determine witch trim buttons effect the props. The only way to do this is durring flight. At low power, since you are working with 4 axis, each set of 2 buttons will effect the rotational speed of 1 motor. Typicaly in this set up, the left stick will control power and yaw(up and rotation left and right), while the right stick controls direction and pitch.(forward/reverse and bank left or right) Here is what I think you need. The left side bottom butons, control horizontal control. If you take off and notice the helo going to the left(banking, not turning) click the right button to attain horizontal stability. If you notice it is going slightly forward click the bottom button on the right side of the left stick. The same can be said with the axis control on the right stick. I hope to see this aircraft on youtube, as there is a shortage of these flying stabile anywere. good luck.
Apr 22, 2013 | Toys
User needs to use left hand for forward and reverse and would like wires switched
that's it,
regards
Dec 17, 2012 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
When cutting with mywild thing it alwaqys cuts to my left and not in a straight line.
The cutting teeth are longer one side than the other, this is always a problem if you sharpen the chain more on one side than the other, you will need to check which side is longer and file them down to the same length as the other side, this is why when sharpening a chain you always do the same amout of file strokes to every cutter.
Sep 15, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing will not restart after 15 min.
Try venting the gas cap for a moment and attempt restart. If it starts, check for a plugged tank vent which should be a bronze disk set into the tank casting and located above the filler cap under the left side cover. When you changed the plug, was it wet with fuel inside? Also, check for spark at the plug when it won't start. You may have ignition problems that occur with engine heat. Hope some of this helps!
May 20, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need to know the torque settings on the head for a 94 jeep grand cherokee laredo
Assuming the motor is an inline six
1.Middle bolt is number 1.Clockwise torque to 22 f/lb
2.Same pattern to 45 f/lb
3. same pattern to 100 f/lb
Be sure to use loctite 592 to the threads and some head gasket sealer to both sides of the head gasket.
Hope this helps
Oct 18, 2009 | 1994 Jeep Grand Cherokee
Xbox 360 controller left analog stick
If you bought it brand new, contact Microsoft ASAP.
Otherwise, no luck. Just an unfortunate side affect of playing a 360.
Apr 04, 2009 | Microsoft Xbox 360 Wireless Controller
Cruise control shuts off with left turn signal
Just a wild suggestion not at all specific to your car... Check the bulbs in, and functionally of, your turn signals and tail lights and brake lights. I'd don't know if it still applies, but once upon a time a burnt out bulb would cause the cruise not to work (some kind of a safety thing).
Aug 10, 2008 | 2003 Mazda MPV
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
