Question about Samsung Xpress C410W Laser Printer
Removal upper fuser heat roller in samsung xpress c410w
I need replacing the fuser roller
  • 691 Answers
SOURCE: Printouts have type ghosting
Change the fuser unit if you have to hand. The problem is likely caused by a lack of pressure from the pressure roller. Also check the transfer roller for a similar ghost image.
Posted on Sep 14, 2008
  • 1447 Answers
SOURCE: Solution for fuser....
no need to change it just wash thermostater
Posted on Jun 28, 2009
  • 51 Answers
SOURCE: Error Engine Fuser low heat
possibly the fusers thermostat is displaced. it rides very close to the roller to get an accurate reading, look for 2 wires into a black "thing" toward the middle of the roller. this is a thermistor which sends its reading to the mainboard. check if the fuser is getting very warm, there is a thermo couple in series with the fusers power so it wont overheat but if its getting hot and the printer doesnt know it then the dammaged/displaced thermostat would be the thing to look for,
Posted on Sep 28, 2009
  • 4 Answers
SOURCE: how to remove covers and fuser unit?
Ive got the same problem :( and because i used compatible cartridges, it apparantly voides the warrantly, so staples will not fix it :( so im now stuck with a £260 uselss printer :( good luck getting it fixed.
Posted on Feb 18, 2010
  • 4338 Answers
SOURCE: The red fuser roller in
You have to buy a new fuser unit. They have it at these sites:
$102.15 Samsung CLX-3160FN Samsung Genuine Brand New Fuser Unit
Fuser Unit Good for Approx. 100,000 Mono Copies or 50,000 Color Copies (JC96-04088B
Posted on Dec 03, 2010
How can I enter the Tech Mode to reset the counters?
Imaging drum reset chip Ebay £15
Mar 15, 2016 | Samsung Xpress SL-C460FW Laser...
Hello there. I have a Samsung C410W Printer which won't print and keeps giving me a "Paper Jam" error message, when there ISN'T one. It is out of Warranty, was bought secondhand, but it is relatively
You need to check all the flags in the paper path to ensure that they move freely. It is pretty common that when removing a paper jam that these little flags get knocked out of position.
Dec 08, 2014 | Samsung Xpress SL-C410W Laser Printer -...
Printer fuser failure
replace the fuser. Fusers have a life span based on the number of prints and not the age.
If you dont print alot on the unit, consider contacting the retail store or manufacturer
Feb 12, 2014 | Samsung Office Equipment & Supplies
It says c then 50
A C5 error code means that you have a problem with the fuser unit. The fuser is not warming up correctly. You will mostly have to replace the upper fuser roller or the upper fuser unit. The heating ubit sometimes arch's though the fuser roller. You will need to resolve the problem before the code clears, you may also have to replace the fuse on a small PCB next to the rear of the copier..... Good Luck
Oct 30, 2010 | Minolta EP1031/1031F CS/PRO Copier
Replacing upper fuser roller
there really is no need to remove the cleaning web when replaceing the upper fixing roller.... it stays in place and will not present a problem apon replacement
Jun 04, 2010 | Canon imageRUNNER 5000 Copier
Making a cracking noise from the fuser unit area
I'm assuming that the cracking noise occurs as the printed page is passing through the fuser?
Check your print settings to ensure that your paper stock is not set to heavy (card). This setting applies extra heat to the fuser to 'fuse' the text to the paper, which is what you want for card, but if you are printing normal stock, it will overheat the toner causing it to stick to the fuser roller on the way through and make a 'cracking' sound as the paper peels off the roller.
Whilst it is possible that there is a fault with the thermostat and the fuser heater is not switching off, this is rare. If you have been printing a number of pages at an incorrect paper stock setting you may need to clean baked text of the upper fuser roller, in which case, apply the following procedure.
After switching off the pirnter and it has had time to cool you may be able to clean the upper fuser roller with a rag moistened with a little methylated spirit, although you will not be able to rotate the roller fully without removing the fuser assembly from the printer. If the roller is physically damaged however, eg. scoured, cleaning will not resolve the problem, the roller will need to be replaced. This usually occurs after a long life, so it is generally best to install a new or reconditioned fuser (includes new rollers, top and bottom and new heat lamp).
Mar 19, 2010 | HP LaserJet 2420 Printer
Upper (gray) fuser roller needs replacing, (tear on 1 side).
If you are handy it is not hard to replace the upper fuser roller you will need a small phillips screwdriver and pliars
the fuser lamp goes through the fuser roler so youmust disconnect the power leads to the lamp and remove the lamp
You do have to release the back side of the drive
gear on the fuser roller
when you install the new roller be sure to put some silicone fuser oil on the cleaning pad
take your time good luck
Jan 04, 2009 | Office Equipment & Supplies
Samsung Xpress C410W Laser Printer Logo
106 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
