Question about Samsung Xpress C410W Laser Printer
How to remove fuser heat roller to Samsung laser printer xpress c410 w
drifterK
  • 4924 Answers
SOURCE: Samsung ML-2571N Laser Printer - paper jammed around roller
http://www.samsung.com/us/consumer/detail/support.do?group=printersmultifunction&type=printersmultifunction&subtype=monochromelaserprinters&model_cd=ML-2571N/XAA&mode=C
this link will guide you to the site with the user guides...but in short ..all ya have to do is to be careful and to open and remove the paper...there are not many things that may be damaged in the process...but there is a certain order you have to follow in doing it ...and a few devices that has unusual safety removing gadgets...
Posted on Jun 13, 2009
  • 4 Answers
SOURCE: how to remove covers and fuser unit?
Ive got the same problem :( and because i used compatible cartridges, it apparantly voides the warrantly, so staples will not fix it :( so im now stuck with a £260 uselss printer :( good luck getting it fixed.
Posted on Feb 18, 2010
SOURCE: ML 3561ND engine fuser. low heat error??????
It's in the onboard computer system itself. This is a pre-set by the company that is designed to force you to service the unit, buy parts, etc., whether you need them or not. It is dirty pool I agree, but unless you know how to get into the machine's maintenance menu to re-set all those factory settings, you are pretty much screwed.
This is a nice printer, and what Samsung has done here is a travesty to our trash problem. It will turn out that it is much cheaper to just buy a new printer and toss the one you have, ergo, you are throwing away a perfectly good working printer all because the greedy foreign corporation knows "Stupid Americans" will buy more and more.
There is a way to get in, but it is VERY hard to do, but you are welcome to try:
You can enter the menu in this way:
Start up the machine with push in the buttons "online" and "cancel"
--You will see the message "Download mode press online key"
Press about 15 times the "menu" key
--You will see the message "Uncheck consumable mode"
Press about 15 times "menu" and 5 times "enter"
--You will see "Press access key"
Press a few enters
Press 3 times "cancel"
Go to the EDC mode
-- you will see "press access key"
Press "cancel"
Go to maintenance and initialize the parts you like to reset.
(sometimes you have to try a few times; don't wait to long between each of the steps)
Your printers are NOT broken. It is all in the design and how the likes of Samsung, Sanyo, Toshiba, etc., have figured out a way to screw Americans over, why, it's the favorite Euro/Asian pastime, see how many times you can get brainless Americans to buy your product over and over and over and over, on and on ad nauseum.
I wish you all much luck!
Now, here is what I did, and I do NOT recommend it:
I went to Comp USA and found the floor model. I wrote down the serial number off the back, went home and called Samsung with that serial number - and I was told "Your printer is still under warranty, we'll send someone to your home to repair or replace" How lovely of them. And replace it they did. Now, I haven't gotten the error message with this one, but if I do, I'll do the same thing again. Screw me once, shame on you, screw me twice . . . . .
Posted on Feb 27, 2010
  • 113 Answers
SOURCE: Samsung ML2571N Fuser Open heat error - Fuser Is Good
Hi Kevin,
The main power supply board in short we call it (SMPS) the error you got is quite common that the main power is not getting in to the transformer in the correct voltage. Normally is to replace the SMPS and the fuser as well.
For more Technical test on the SMPS 1st of all we will test the fuse on the SMPS which is located at the bottom right hand corner. using a multi-tester, 2nd will be the capacitor and 3rd which is the last will be the big and small transformer with power on. note the last test is dangeroures unless you are a electrician experts.
hope this help :)
SamsuTech
Posted on Apr 17, 2010
  • 113 Answers
SOURCE: Samsung CLP-650N Engine Fuser Inverter Error 3
the fuser and dave home drive got to be repalce.
most likely it has worn out.
Posted on May 13, 2010
Scx 4200 takes to heat
Remove the fusing unit ,clean the rollers if necessary change the upper or lower fuser roller.
Jul 21, 2014 | Samsung SCX 4200 All-In-One Laser Printer
Samsung ML3051N open heat error cycle power
check the fuser assy thermostate , if pressor roller melt then change the fuser assy
Feb 19, 2011 | Samsung ML-3051N Laser Printer
Open heat error in my printer model SCX-4521F
open heat error sounds like the fuser lamp is blown. The fuser lamp is inside the hot roller at the back which melts the toner onto the page. It is not really a user serviceable part, you would need someone qualified to repair/replace the fuser.
Apr 28, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Samsung clp-300 Error message is "fuser low heat error
The problem is that the Fuser is not heating up. Its possible you have a broken heat lamp.
The Fuser will have to get replaced, if you want to spend less but more labor, the heat lamp can be ordered.
Mar 07, 2010 | Samsung CLP 300 Laser Printer
Error Engine Fuser low heat
possibly the fusers thermostat is displaced. it rides very close to the roller to get an accurate reading, look for 2 wires into a black "thing" toward the middle of the roller. this is a thermistor which sends its reading to the mainboard. check if the fuser is getting very warm, there is a thermo couple in series with the fusers power so it wont overheat but if its getting hot and the printer doesnt know it then the dammaged/displaced thermostat would be the thing to look for,
Sep 28, 2009 | Samsung CLP-600N Laser Printer
Low heat fuser
The fuser is not heating up, a lamp could be out, but usually the rollers are worn and it's best to replace the fuser completely.
Jun 29, 2009 | Samsung CLP-510 Laser Printer
Samsung CLX Printer printing unevenly
it is possible that this is a fuser prob, fuser works applying heat and pressure, if the roller, either the pressure roller or the fuser roller is defective this is most likely will happen too, you might want to  check the number of copies or prints made
Mar 22, 2009 | Samsung CLX-2160N All-In-One Printer
Overheating
1.call service. it's dangerous becouse too hot fuser section can make open fire. teristor in fuser damaged, or temp.sensor can not detect temperature of heat roller. 2. clean pick up rollers with special fluid. If thats not help - replace rollers. 3. see fuser, laser and cartridge.
Oct 14, 2008 | Samsung ML 2010 Laser Printer
Samsung scx4216
Open heat error, you have a fuser problem, replace fuser. Fuser consists of Upperheat roller, lower heat roller, exit claws/rollers, and a heating circuit with a lamp, thermal temp sensor (thermistor) and a thermal fuse/cutout.
You could measuring fuser removed from machine, checking lamp etc for open circuit, thermistor should be neither short or open circuit.
These days we dont, we just change assembly due to it being a common constantly wearing part, and if for example I pull it apart, fix the lamp, put it together then soon enough I will need to pull it apart again to fix worn roller etc.
I could give you the part number ... JC81-01690A but dont use it, cause that part is for 220volt cause thats what we use in Oz, so contact Samsung and ask for dealer in your country who can supply you.
P.S. Fuser is the Hot bit (180 deg c) at back near paper exit that bonds(melts) the print into the paper.
Nov 14, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Engine Fuser Low Heat Error
there is a 2 wire device (thermistor) that rests against the fuser roller to measure the temperauture. if the fuser is getting quite hot, suspect the thermistor to be either dirty (remove and clean it with alcohol) or defective. if fuser not getting hot, then suspect burned out fuser heater (look inside fuser roller for a long light bulb).
Aug 28, 2007 | Samsung CLP-510 Laser Printer
Samsung Xpress C410W Laser Printer Logo
74 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
