Question about Kenmore Refrigerators
  • 58 Answers
SOURCE: Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Posted on Oct 31, 2007
  • 126 Answers
SOURCE: kenmore elite water filter
just leave your filter installed
Posted on Dec 11, 2007
  • 85 Answers
SOURCE: Does this model have a water filter?
It does not have one. You can get one that installs in-line in you water line to the refrigerator if you want one. Have a great day!
Posted on Jun 01, 2009
  • 78 Answers
SOURCE: Hi, have Kenmore fridg model #106. I was told
The water filter is that round looking thing at the bottom of the refrigerator on the front grill. I can see it in the picture you provided. Sometimes, in higher end models, there will be a cover that turns and snaps out. Most units just have a place to grab with your fingers and turn counter-clockwise (to the left as if you were unscrewing it), but don't unscrew it. It only takes a quarter turn to disconnect the filter.
Pull out what you just disconnected and you will have in your hand a plastic (or metal) canister that is the filter. Go buy an exact replacement and usually you have to take the "handle" you used to remove it off the old filter and place it on the new filter.
Oh, probably a good idea to turn your ice maker off and block anyone from using the water dispenser or better yet: pull the refrigerator out and turn the water off.
Good Luck!
Posted on Oct 10, 2009
  • 528 Answers
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
Posted on Dec 30, 2009
If i fillter my water befor the refrig water fillter refrig fillter life is
You didn't complete your sentence You wrote "water filter refrig life is" If you meant that the refrigerator life is or would be extended. If that is what you meant then the answer is no. Please post your question so that I can better advise you.
Mar 01, 2014 | Whirlpool Refrigerators
Kenmore model 79578502800 refrigerator error code 1F. icemaker does not work
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 05, 2010 | Refrigerators
Kenmore refrig model #106-56232400 ice maker
Dec 30, 2009 | Kenmore Refrigerators
I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Model 78182891 Coldspot with excessive water Collecting in Refrig
a plugged or frozen drain is a common problem that occurs from time to time in just about all refrigs so the answer is yes it may occur again in the future. But folllow theses directions and it will probably not occur again for 2-3 years.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Post back if you have any questions and I'll gladly help you out Thanks Peyton
Mar 17, 2009 | Kenmore Refrigerators
Faulty compressor..
one of the windings on the compressor have burnt out or are faulty..
however it could be a faulty relay/klixon or capacitor and not the compressor
most likely is the compressor job for the experts really.
Jan 10, 2008 | Refrigerators
Refrigerators Logo
32 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
