Question about Dehumidifiers
How to set an small shrimps drying factory, how to manipulate, sanitise, cook, salt use, dry, level of humidity, take out head and skin, packing and sale.
SOURCE: Humidifier that never shuts off.
I am having the same problem with mine and it has started freezing up for no reason. Did you get any answers
Posted on May 19, 2007
  • 340 Answers
SOURCE: Moisture not collected
low on freon is the compressor running?
Posted on Jun 18, 2009
  • 12 Answers
SOURCE: Fan runs, all controls work compressor does not run.
It sounds as if the unit has lost it's refrigerant charge. Take to small appliance repair for confirmation, but it probably leaked out.
Posted on Jun 29, 2009
heatman101
  • 43501 Answers
SOURCE: My LG Dehumidifier model LHD45EL stopped working.
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Posted on Jan 27, 2011
heatman101
  • 43501 Answers
SOURCE: Everything seems to be working
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on May 27, 2011
Can my 3 in 1 air cooler also be used as a dehumidifier
an air cooler is a dehumidifier by definition
It cools the air around the evaporator giving you cool air and at the same time any humidity in the air is condensed into water and drained off
to understand air conditioner principles it goes something like this
we sweat and the more we sweat is because of the humidity in the air
if the air temp is 30 degrees c with a humidity of 75% then we feel that it is a very hot muggy day simply because the humidity stops the sweat from evaporating and allowing the skin to cool
Now it you take the humidity out of the air and at the same day temperature , you will actually feel cool because the sweat can evaporate and cool the skin
now you can understand that the best setting for air conditioning is 25 degrees c because if the setting is lower then the skin gets too cool because there is no humidity to restrict the evaporation of the sweat
modern spilt systems have a mode called comfort where the fan and the compressor work to maintain a constant level of humidity when sleeping and you don't get cold especially towards the morning
Jul 29, 2015 | Dehumidifiers
Just purchases a kenmore dehumidifier and appears to work, but the bucket is completely dry.
ck your settings on control panel , lots of times they set the set point high at factory so it wont turn its self on to remove water . also ck your rooms available humidity level sometimes there's not enough water in air for one to remove much
Feb 13, 2014 | Kenmore Dehumidifiers
Dehumidifer runs constantly,but captures no water in bucket
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit no
LED Screen, set the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity Humid-i-stat has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 23, 2011 | Kenmore 54501 Dehumidifier
Dehumidifier does not gather water in the bucket anymore
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
manually/mechanically control unit, set the humidity level to Maximum.
level
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Kenmore Dehumidifiers
Fan running..just not dehumidifying all of a sudden...Maytag+45-Pint+Dehumidifier+M7DH45B2 7 yrs old
Todd, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled model, set the humidity extraction level on Maximum.
level
in basement applications . Raising the unit up off the floor,
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity connenser sensor has failed. These things usually occur in units that are 5 years old or older.
I hope this helps you to troubleshoot and solve the problem.
Jul 09, 2011 | Maytag Dehumidifiers
Everything seems to be working although I've set the humidity level at 50 but container still dry and humidity level still remains at 70. I trouble shooted everything per manual by cleaning filter...
heatman101
May 26, 2011 | DeLonghi DE500P Dehumidifier
What is the right temperature setting when the room has a lot of water?
You can't control the temperature setting but you can control the humidity level. I would start somewhere between 35 and 40%- making sure to empty the dehumidifier promptly when full. 40% humidity will prevent mold and mildew growth- and that musty smell- but keep the room from becoming too dry.
Mar 01, 2011 | Kenmore 54501 Dehumidifier
What setting should I set my dehumidifier for % humidity when the room temperature is 68
THE LOWER THE % SETTING, THE MORE MOISTURE THE DEHUMIDIFIER WILL REMOVE!!!
I have a Provic dehumidifier mainly to remove damp from walls in my 1900s terraced house ( 3rd DPC failed, another on its way). I've read a lot about the technical side and all I wanted to know was 'do i set it on the highest or lowest % to extract moisture from the walls'. I rang the Managing Director at Provic (his contact details are given on their website) who was very helpful. He advised that the lower the setting, the more damp would be removed from the walls and therefore the air, as the water passes from the wall into the air. My DH ranges from 40% to 70% so he advised me to set it at 40% in the worst affected room to remove as much moisture as possible from the walls. As the moisture is removed, the DH will collect less water and set itself to the correct level anyway. He advised me that when as much water as possible has been removed from this room and the DH % will not drop any lower, to move it to a more central position in the house, such as the hallway to then start setting the rest of the house to the correct humidity level. I set the DH to 40% and left it on overnight closing all doors to the affected room and removing containers of water such as a vase of flowers. When I got up in the morning it had switched itself off as it had already collected 3 litres of water! You do have to be careful not to over dry the air as everything, furniture and electricals, naturally needs moisture, but for a short term, quick drying solution, this level is ok.
Hope this helps!
Jan 01, 2010 | Maytag Dehumidifiers
Hi, bought one two weeks ago. Try it on auto and set at 'normal', and 'dry' and the unit will stay running with out stopping over a period of day and a half. Collected about 1/3 tank of water. Phoned...
If you are in a very humid room or area it will not shut of until it reaches desired humidity% level that is set. If it is reaching the set level and not turning off I would return it.
Oct 06, 2009 | Whirlpool AD50USS Dehumidifier
I NEED TO KNOW WHAT PERCENTAGE MEANS ON A DE-HUMIDIFIER
In plain English, the Percentage setting on your de-humidifier is the percentage of moisture that you want to maintain in the air. Relative humidity level range from about 10% (VERY dry air) to almost 100% (VERY damp air). When relative humidity is 100%, water vapor in the air will turn into rain, condensation, dew, snow or frost. 50% humidity is usually a comfortable level, but that will also depend on air temperature. The more moisture there is in the air, the warmer it feels and conversely. Warm air will hold more moisture than cooler air.
Your body is cooled when moisture on your skin evaporates into the air, carrying body heat with it. As the humidity in the air rises, less of your body moisture is able to evaporate and thus your body feels wamer. Lower humidty allows moisture from your body to evaporate more quickly and you feel cooler, both at the exact same temperature.
Jun 28, 2009 | Kenmore 54701 Dehumidifier
Dehumidifiers Logo
96 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
