Question about Fisher and Paykel Dishwashers
Fisher and paykel error code 6 on dishwasher - Fisher and Paykel Dishwashers
  • 1,381 Answers
The code E6 is for the flood switch
Pull the appliance out, tip it back about 45 degrees and see if water runs out of the base.
If it does, drain the base (under where the tub) completely and the anti flood should reset.
If there is an aquastop device on your fill hose, after draining the base, turn off the water supply, disconnect the aquastop device and allow it to de-pressurize. Connect it back up and try again.
If it happens again, you'll need to check for a leak.
The normal cause is over foaming, using multifunction tablets and rinse aid, or just spilling rinse aid.
Posted on Dec 28, 2016
I have a fisher Paykel dishwasher and a e20 code came up does this mean it is blocked
Hi Vivianne
I found the definition of some error codes but I don't know if any of these will apply to your appliance:
Fisher Paykel Fault Codes
I hope this helps
May 29, 2016 | Fisher Dishwashers
If the power is connected and you are able to program the wash cycle, then it appears the drawer close sensor is failing. The controller is unable to detect drawer close and start the wash cycle. Need to replace the sensor or clean it. The location is shown on page 10 item 5 (tub home sensor) in this parts manual
Mar 16, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Need to get out old motor rotor assy so we can put new one in.
This video will wok you through your Fisher Paykel repair, how to fizz a f1 error code and how to replace the rotor.
Sep 29, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 error code continuosly
here is a link to a downloadable repair video. This video explains how to repair a f1 error code and how to replace the rotor.
Mar 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
What is F4 error on fisher paykel dishwasher?
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Oct 29, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
U2 Error Fisher Paykel dd-602 dishwasher
Hi there, Error U2 -
Possible Causes - Loading
Check loading to ensure no items extend
beyond the height of the drawer.
Good Luck!
Sep 01, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Error code. Fisher and Paykel Dishwasher
well since you asked on the 5th July, and no reply, doesnt look like you may get one. I thought thats what this site was about??
Jul 05, 2008 | Dishwashers
Fisher Paykel Dishwasher Door Open error code
If it is a dish drawer type there is a clip at the rear of the drawer that holds the drawer closed. you will need to withdraw the drawer partially to look in. with the drawer open the fingers should be facing towards you. If not you will need to reach in and pull the top of the fingers towards the front. there is a replacement arm that holds the pipes and cables away from this part.
Nov 18, 2007 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwashers Logo
209 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
