Question about Intel Computers & Internet
I am usubg 845 gvrs motherboard now I want to installed extra internal harddisk what will be ideal harddisk and size
  • Intel Master
  • 32,281 Answers
The size of the hard disk depends upon what type of programs you are running and the amount of data you need to store.
Programs that create large amount of data are audio and video files.
The tpye of hard drive depends on what type of disk controller you have, it could be IDE or SATA disk controller, you need to check your computer's hard disk controller.
The average hard disk capacity is 160 Gb to 180 Gb and goes up to 1 Tb, but the largest capacity drive your cmputer can support will depend upon the BIOS.
Posted on Jul 21, 2009
845 chipset board this borad samsung harddisk ditect but xp not install in hadisk, so plese give me soliution
If you have an Intel motherboard then -
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Dec 07, 2010 | Intel Motherboard
Swaping hdd 845 motherboard to 915 motherboard
its always safe to have data backed up
u can swap the HDD
but bootup with the Win2K CD in the Drive and after the files are loaded at the first screen select install then after it detects the OS select R (Repair) and this will reinstall the operating system files and then you can use the system as before though u may have to install the device drivers and motherboard drivers
for any other clarifications u can place a comment in the same question or u can mail me at mail2pvs@gmail.com
Jul 30, 2009 | Intel Pentium 4, 3.0 GHz 530...
HARD DISK IS NOT DETECTED
check the data cable and power cable connectors of the harddisk, otherwise the hard disk check on other computer.
Feb 14, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Maximum size of hard disk supported
Hi Bijay.
Neither is at fault. Please click on this Seagate link:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=How_To_Install_and_Troubleshoot_ATA_Hard_Drives&vgnextoid=559e5b1142aec010VgnVCM100000dd04090aRCRD
Scroll down to: Partitioning the drive in Windows XP / Windows 2000 (for systems where this is the 2nd drive in the system).
Follow the instruction on the web site.
This Seagate web site will help you setup the Seagate 160 drive.
If you feel the drive is still at fault you can run Seagate’s SeaTools. Click on the next link:
http://www.seagate.com/www/en-us/support/downloads/seatools
This software will check the 160GB drive.
(Follow the online instructions for), SeaTools for DOS.
In a Windows XP system & using a FAT 32 & a cluster size of 16kb instead of NTFS. Windows will see the total size of the drive but can only access 149GB of drive space. 11GB of drive space will be used by the FAT. File Allocation Table. The FAT is windows guide to every cluster on the drive.
XP uses NTFS & sets each cluster to 4kb. This 4kb size lowers the total usable GB size & uses more GB's for the FAT. You're 127GB size may be correct for a Win XP system using a NTFS file system. The FAT is using 33GB of drive space as a locator for every cluster on the 160GB drive.
Help with understanding the NTFS file system: http://www.microsoft.com/windowsxp/using/setup/expert/russel_october01.mspx
Bijay if you are still having trouble understanding please post any questions here.
Mike
Aug 12, 2008 | Intel D845GLLY Motherboard
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
Intel 845 GVSR drivers for windows vista
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS....
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key
and
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
Apr 09, 2008 | Intel D845GVSR Motherboard
No display
hi
if you known about your all SMBS, RAM ,, PROCESSER, & HD Are all ok
  1. chack your ram then clean your ram slot
  2. smps ok
  3. about me your screen is black
  4. chang your bios battery 1st
  5. you use any video card...
Mar 03, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Nov 13, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
264 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
