Question about The Watches
How do I set the days of the week to change..? The hour and minute hand work fine but the day of the week won't change
escapement
  • 2334 Answers
SOURCE: Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Posted on Mar 15, 2009
SOURCE: Set hour minute on Omega Constellation Day Date (Quartz)
Found solution at: http://www.timefactors.com/omegacon.htm Regards, Joe
Posted on Jun 11, 2009
  • 183 Answers
SOURCE: Suunto watch keeps resetting itself. Changed
You wouldnt think a whole lot could go wrong with a Suunto battery change. If they had trouble getting the coin access back off and unscrewed the case then the button contacts might be out of line causing your problem. You might also check to be sure that they put the right battery in and that there are no pry marks as sometimes there are problems getting the battery out. If any excessive pressure was placed on the circuit board and it cracked it will need to be replaced.
Posted on Sep 22, 2009
  • 101 Answers
SOURCE: Citizen watch secondhand not moving
its a solar watch meaning you have to completely charge the watch under artificial light for 24 hours or full sun for 6 hours
Posted on Aug 19, 2010
ansel_albert
  • 246 Answers
SOURCE: How do you set the
You only have to pull the crown of your watch to its third position ( to set the time) so that if you turn it until it reaches 2am or 3 am the day moves and you have to continue it until you reach the exact day of the week. Then, you don't have to set the 24 hour on the watch because the time remains the same on with the time on your watch. observe it. I hope that i had solve your problem.
Posted on Jul 09, 2011
How do i set the day (Mon-Sun) on my ax2013 watch?
When you pull the crown out there are two positions. The first is the day/date setting position. Turn the crown one way and the date changes, the other direction the day of the week changes. Set both the day and date to yesterday. It will become evident why when you finish. Now pull the crown all the way out and notice when you turn the crown the hands move. Advance the hands to the 12 o'clock position in a clockwise direction. As you pass 12 the date may begin to change. If not then you now know that was noon and not midnight because the date only changes at midnight. If the date did not change advance the hands all the way around 12 hours. This will now be midnight and the date should begin to change. It may be almost instantaneous or may take until 12:30 or so. Continue advancing the hands to 4 o'clock. You should see between midnight and 4 the day of the week advance. Now the day/date are correct for today and the final step is to set the correct time. Remember, you are now set a 4 AM. Advance the hands to the correct time. That means if it is 3 in the afternoon, you must advance past noon to 3. You cannot go backwards. That would be 3 AM!
Mar 24, 2011 | Giorgio Armani A|X Armani Exchange Black...
Tip
How To Set The Time/Calendar For Your Seiko Watch
<span style="font-weight: bold;">Time Setting for Models Without Calendar</span><br /><span style="font-style: italic;">Note: When setting the minute hand of a quartz watch, advance it a few minutes ahead of the time and then turn it back to the exact time.</span><br /> <ol> <li>Pull out the crown all the way. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Time/Calendar Setting for Models With Calendar</span><br /><span style="font-style: italic;">Note: The date will change gradually between 9:00 PM and 4:00 AM. For some models, however, it will change instantly when the hands pass the 12 o'clock marker at midnight.</span><br /> <ul style="font-weight: bold;"> <li>For models with date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol> <ul style="font-weight: bold;"> <li>For models with day and date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Turn the crown in the opposite direction until the desired language (bilingual) for the day before the desired day appears in the calendar frame. <span style="font-style: italic;">Note: For Cal. 7009 and 7019, push the crown back in to the normal position and then push it repeatedly to set the day.</span><br /></li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Note:</span> Do not change the calendar between 9:00 PM and 4:00 AM as it may not change properly. If it is necessary to set the calendar during that time period, first change the time to any time outside those hours, set the calendar and then reset the correct time. When the day shifts automatically to the next day, the other language will temporarily appear.<br /><br /><span style="font-weight: bold;">Note:</span> When setting the hour hand, check that AM/PM is correctly set. The watch is designed so that the calendar changes once in 24 hours.<br /><span style="font-style: italic;">Turn the hands past the 12 o'clock marker to determine whether the time is set for the AM or PM period. If the calendar changes, the time is set for the AM period. If it does not change, the time is set for the PM period.</span><br />
on Feb 15, 2011 | Watches
How to set the wr330 watch lost instructions.
On the face of the watch, there are four buttons arranged around the circle of the watch face in four positions. Starting with the upper left hand button (labelled SET), and working clockwise around the face of the watch (to ADJ., EL, and MODE), I'll label the buttons "A", "B", "C", and "D".
In other words...
Button "A" is the button labelled "SET" in the upper left hand corner of the watch.
Button "B" is the button labelled "ADJ." in the upper right hand corner of the watch.
Button "C" is the button labelled EL in the lower right hand corner of the watch.
Button "D" is the button labelled "MODE" in the lower left hand corner of the watch.
Setting the Time.
1. Press and hold D as if you were setting the alarm. As above, the stopwatch will momentarily appear and then after 2 seconds the alarm time will appear with the hour flashing.
2. Press and release D and the seconds on the time of day will begin to flash.
3. Press and release B to reset the seconds to zero provided they are below 30. If they are above 30, the seconds will reset and the minutes of the time of day will advance by one.
4. Press and release A to change from flashing seconds to flashing minutes/flashing hours/flashing day of the month/flashing month of the year/flashing day of the week. In each flashing mode, pressing and releasing B advances the value by one unit.
5. Press and release D to exit time setting mode.
Mar 16, 2011 | Armitron Digital Sport #45/6967PNK Watch
HOW TO CHANGE THE TIME ON MY DIGITAL WATCH IT HAS 4 BUTTONS ON THE TOP LEFT IS "LIGHT" ON THE LEFT "MODE" ON THE TOP RIGHT "START" AND ON THE RIGHT IS "RESET" THE...
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Oct 29, 2010 | Watches
How to set date on it?
Thank you for contacting FixYa.
Pull the crown out to position No. 3, turn clockwise to go to hour and minutes hands; the small dial showing days of the week will move, and the 24-hour dial will also move correspondingly.To set the date, pull the crown out to position No. 2 and turn clockwise until you have set the desired date; push the crown back to position No. 1.
Multifunction watch:Pull the crown out to position No. 3, turn clockwise to go to hour and minutes hands; the small dial showing days of the week will move, and the 24-hour dial will also move correspondingly.To set the date, pull the crown out to position No. 2 and turn clockwise until you have set the desired date; push the crown back to position No. 1.
Aug 25, 2010 | Fossil BQ9177 Wrist Watch
How do I change the "day of the week" on my Tommy Bahama 1072 watch?
But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date! Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch! If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle. Granted, you may have to reset your Day and Date again since you just advanced it, but at least you'll be in the correct Time Zone! Happy Spinning! google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Aug 16, 2010 | Watches
How do you set the day of the week?
Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
  • Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
  • Step 2 Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
  • Step 3 Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
  • Step 4 Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
  • Step 5 Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
  • It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
    Aug 11, 2010 | Watches
    How to set day of week mini dial?
    Pull out the crown and advance hands forwards. When the hour and minute hand will pass 12 o'clock (midnight), you will notice the day hand will jump to the next (following) day. Advance hands as long as needed to reach the desired day.
    Rate me, please.
    Jul 23, 2009 | Invicta Square Angel Diamond Chronograph...
    Changing the hand time only w/o changing the digital time
    For Casio Waveceptor:
    --- A
    ( ) Button Reference
    --- B
    Set in correct order:
    1) Hand Home Position
    2) Digital Time Set
    1) Hand Home Position:
    Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
    Press B to exit Hand Home Position mode and enter Timekeeping Mode.
    2) Digital Time Set: (hands will self set when done)
    Press and hold B for 5 seconds to enter setting mode.
    Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
    <Order of Items to Set>
    GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
    <Setting each Item>
    GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
    Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
    Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
    For each item, Press A to advance, and B to set.
    Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
    Good luck,
    Techjoel
    May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Setting day and date on timex watch
    Pull the stem out part of the way not all of the way. This will allow you to change the date quickly without the day moving.
    Nov 26, 2008 | Timex 27191 Wristwatch
    Watches Logo
    13 people viewed this question
    Top The Watches Experts
    John mullen
    D. E. Hev
     Larry
    Larry
    Are you a The Watch Expert? Answer questions, earn points and help others
