Question about Philips 42PFL3603D/F7 42-Inch 1920 x 1080p LCD HDTV Black
I replaced power board on a philips 42 " tv model # 42pfl3603d/f 2009 model . i get great picture and sound but can not adjust volume with remote or tv pad..i can get a menu but can not access.
2 Suggested Answers
djneo1477
  • 25 Answers
SOURCE: I replaced power board on a philips 42 tv model # 42pfl3603d/f 2009 model . i get great picture and sound but can not adjust volume with remote or tv pad..i can get a menu but can not access.
¡Hola amigo su problema es exclusivo del control remoto de su tv al parecer esas teclas ya no le funciona valla al panel del tv si ah? no le funciona tampoco yo le recomendar?a revisar el panel del tv presione en su control el mute si trabaja el sonido de su tv esta bien si el volumen continua fijo despu?s de revisar el panel y este estar funcionando bien entonces es un problema de la m.b del tv o sea la placa principal a veces una falsa soldadura es todo el problema espero q resuelvas tu problema..
Posted on Dec 31, 2016
Testimonial: "thanks but i can not read ..."
Dec 30, 2016 | Philips Televison & Video
I have a Philips 42" TV mod 42PFL3603D/27 serial;YA1C0824019426 Does not turn on any more the red light at the bottom of the set does not come on either
check for bulging capacitors on the power supply board. you will have to remove the back cover from the television set to get a good look at the power board. If you do notice swollen capacitors, desolder the bad ones out and solder new ones in.
Sep 19, 2016 | Philips 42PFL3603D/27 42 in. LCD TV
MY PHILIPS MODEL 42PFL3603D/F7 TURNS ON WHEN YOU PLUG THE POWER IN AND THE BUTTONS DO NOT WORK
If the remote works for the set, both it and the buttons on the set go to the same place in these sets.
The Keyboard with the manual buttons may have a lockout feature--it can be locked to prevent children etc from tampering with the controls.
If no function from remote, that could be same issue or another==key board has priority over the remote control.
if all else fails carefully read the owner manual.
May 24, 2012 | Philips 42PFL3603D 42 in. LCD TV
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Feb 16, 2011 | Philips 42PFL7422D 42 in. LCD TV
My tv is actually a 42pfl3603d/f7 , had it for one year, the picture is green, but i can hear sound. what could be the problem?
Ur Tuner signal board is dead.Replaced this board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Mar 13, 2010 | Philips 42PFL3403D 42 in. LCD HDTV
Can't find the remote code for Philips 42pfl3603d 42inch LCD TV
Philips codes are: 011, 056, 043, 017. Try them in this order.
Jul 27, 2009 | Philips 42PFL3603D 42 in. LCD TV
Philips 42PFL3603D/F7 42-Inch 1920 x 1080p LCD HDTV Black Logo
79 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
