Question about Garden
Hi my Morrison bc325s2 when I started it and warmed up , I tried to go full throttle and it would die any reason for this, is it fuel mix with two stroke oil or the carb or fuel hoses blocked?
  • Mark Graham
    Mark Graham Dec 28, 2016
    Not chainsaw,it's a weed eater
    Top Expert:
  • Garden Master
  • 48,384 Answers
If it has 2 adjuster screws on the carby, it could be the high speed screw adjustment
start it and raise the rpms until it starts to falter
adjust the screw in or out until it settles at the setting then increase the rpms some more until the adjustment makes a change
keep going until you get full throttle
If there is only one screw , rekit the carby as it is most likely a diaphragm failing and not pumping the fuel through for the extra rpms
Posted on Dec 28, 2016
  • 239 Answers
SOURCE: Stihl strimmer will not start
Posted on Jan 02, 2009
  • 373 Answers
SOURCE: Poulan chain saw after carb rebuild.
Is thereadjustment somewhere on the saw
I think there is 2 .
Posted on Feb 03, 2009
  • 520 Answers
SOURCE: the saw wont stay running. I start it with full
Sounds like the carb needs to be rebuilt. Those tiny jets will clog easily and need to be replaced. The diaphragm is also a large part of bogging and dieing. Hope this helps.
Posted on Jun 14, 2009
  • 2220 Answers
SOURCE: Homelite Timberman chainsaw won't run anymore
Sometimes the transferred metal feels like compression.
The volume of most chainsaws is so small it makes a HUGE difference in the reading; depending on which end of the compression tester the Schrader valve is mounted (should be spark plug end). If the total cylinder volume is only 2 cubic inches and the hose adds an additional cubic inch you can see how it will impact.
I recommend you join here:
ArboristSite Chainsaw thread (free to join)
There are some threads about using acid to remove metal transfer from cylinder walls. There are some Homelite collectors. There are a bunch of good people that enjoy lending a little expertise. I am not a Homelite guy, I have done some research for Homeys and often you must buy an entire short block.
You may find this helpful too:
Homelite/ (authorized parts supplier) - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
your question impressed me so much I almost did not answer. It is so though and well thought I though you had been at this for a while and knew exactly what to do next and were pulling my leg. Good on you. You will be welcomed at ArboristSite. Good Luck
Posted on Feb 13, 2010
Testimonial: "Very thorough and helpful feedback"
  • 2239 Answers
SOURCE: Model 345 won't start. New
There is a vent in the tank, it is situated on the right hand side of the tank, close to where the fuel hose exits the tank, the early vent looks like a round white pellet, the later vent is a white plug with a nipple on the top, the later vent will just pull out with long nose pliers, the early vent has to be extracted useing a self tapping screw, this of course will destroy the vent.
Posted on Jun 07, 2011
Starts and idles fine and runs with feathering the throttle, but dies when I try to run it full.
Hi Joe:
Try removing and cleaning the muffler. Sometimes there is a fine screen (spark control) that will get covered with carbon. As soon as you try to run at high speed the back pressure kills the motor.
Apr 25, 2015 | Garden
Settings for fuel/air mix?
Hi have you checked fuel filter or filter in the tank also make sure the fuel line has no kinks you say the diaphragm looks good make sure there are no holes or it's not sticking as this will cause fuel level to be low in float chamber and cause fuel starvation.Good luck.
Oct 13, 2014 | 2007 Qlink Legend 250
I have a Morrison bc325s2 and need a user manual
Type a web search: morrison bc325s2 user manual
Jan 26, 2013 | Cameras
Stihl BG55 blower idles fine but when you give it throttle it starts to rev up but then dies?
first you need to let it warm up. one minute. it is 2 stroke. most common issue is too much oil in fuel. mix ratio exact. make sure no water in fuel
Nov 08, 2012 | Stihl Genuine 4229 120 0606 C1q-S68d Carb
Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
May 02, 2012 | Yamaha Boating
I have the Morrison BC 260B S2 Weed Trimmer but I don't have any instrucions for its use. I need to know what the mix of 2-Stroke petrol is and its general operation. This is not mine and the owner doesn't...
I have one of these. The mix is 25 to 1. Before starting use the primer bulb to get fuel through; it says to turn the choke to limit the flow, but I've found mine starts easier with the choke open. To start, flick to on/start position, hold the (safety switch?) flush with the spine, and give it a yank.
Sep 04, 2010 | Homelite Mighty Lite Lawn Trimmer
142 chain saw. Starts but will not pick up when
Check the fuel lines for hardness, cracking, splitting, or end rot. Check the muffler for plugging. Check the carburetor fasteners for tightness. Are you using fresh fuel mix? If the carburetor jets have been adjusted, try turning both CW to stops (lightly) then back out each CCW 1-1/2 turns. Engine should start and run--allow to warm up. Pull the throttle full on, and adjust H needle CW until the engine starts to speed up, but still 4-strokes. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Let idle and adjust L CW for fairly smooth running, but still allows the engine to 'follow the throttle'. Hope this helps!
May 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a huskavarna leaf blower 140 back pac i run it for 5 min then it srarves for gas let off on the throtle for 10 seconds put on full it gos to full rpms the starves agian
Carburetor may need adjusting or rebuilding. I would try mixing up some fresh fuel mixture and try that first. Use gas from the station not from the can sitting in the garage.
Good Day.
Oct 28, 2009 | Husqvarna Backpack Blower, Model No. 356bt
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
