Question about Samsung SL502 / PL55 Digital Camera
What is the Battery Charger connection on the Samsung PL 55 camera
My samsung pl200 won't turn on, battery is fully charged I even tried an extra one still not working... ????
Possible Solutions.
1. Charge the battery
2. If still not turning on, try using a little alcohol and wiping the battery terminal(s) on the battery and the battery terminals in the camera. Use a QTip and allow to completely dry before recharging the battery or inserting it into the camera.
2. Replace the battery with new one.
3. On/Off switch may be defective on camera. Charger may be defective. Wire connecting power from charger to wall socket may be improperly connected or loose.
Aug 16, 2016 | Samsung Cameras
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
My samsung st66 wont power on but if i connect the charger it is starting up but my power button turns to view button function how will i fix this?
If won't power up but with a charger, I guess your battery is dead. You should buy a new battery. Also you should take your charger to an electronic repair shop and get it checked. A bad charger can be the reason of premature end of a battery.
Maybe might help you to read your manual if it has any information about power buttor "trnasmuting" to view button when the charger is connected but actually I find it a lesser problem because normally you don't even should use a Digital Camera with charger connected. If you don't have the manual, you can download it from here:
http://www.2cameraguys.com/pdf/samsung-st66-camera-manual.pdf
Aug 27, 2014 | Samsung ST66 Digital Camera
Samsung TL205 Battery Charger http://www.samsung-battery-charger.com/Battery-Charger/Samsung-TL205-Battery-Charger.html Samsung ST50 Digital Camera Battery...
What a battery of information you have accumulated - you must be a bright spark. Please put a plug in it now.
Jun 27, 2017 | Samsung Cameras
I want to know whether I can recharge the battery as my camera is not working. If so can you pl instruct me as how I shld go about it Thanks
Yes, the battery is rechargeable. To charge the battery, remove it from the camera, insert it into the supplied charger, and plug the charger into a wall outlet.
Dec 07, 2010 | Polaroid t1031 Digital Camera
How to charge battery
You need to use the supplied battery charger to charge the battery. The battery goes into the charger, and then you plug the charger into a wall outlet.
You can download a copy of the manual from the manufacturer's web site at http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCW100
Jun 11, 2010 | Sony Cyber-shot DSC-W100 Digital Camera
Battery charger for my Sony Dsc w-55 digital camera
Hey Reinerd,
According to information provided by the manufacturer, the battery charger for your Playstation Portable is not designed to be used with the battery for your digital camera.
Please keep in mind that most manufacturers will provide lists of compatible battery and charger models in their owner's manual booklets, as well as on their own websites.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 28, 2008 | Sony Battery Charger for PSP
Samsung SL502 / PL55 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
