Question about Video Game Consoles & Games
Using a ditto2x looper with the peavey vypr1 amp I get noise or static interference. How can I avoid the noise . are some channel settings more suitable than others ?
  • 4,487 Answers
No idea what a ditto2X looper is.
Amplifiers can be noisy and this can be caused by components or the internal circuitry being faulty or just plain old, dry soldered joints, dirty or worn switches, rotary or slider controls, connecting plugs and sockets, microphonic valves.
Hum loops are common and difficult to avoid so research can help and in addition: -
Ensure all unused inputs are grounded.
Keep input leads to the minimum length especially on high impedance sources and inputs.
Match source and input impedance as closely as possible.
Posted on Dec 28, 2016
My wii is showing me the 51031
Error Code 51030, 51031, 51032
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
Aug 29, 2014 | Video Game Consoles & Games
Aug 23, 2011 | Nintendo Wii Console
I am getting error 51032
Jul 12, 2011 | Nintendo Wii Console
Internet isn't working right. Say error code 51030
Mar 20, 2011 | Nintendo Wii Console
What does error code 51030 mean
Feb 04, 2011 | Nintendo Wii Console
What is error code: 51030 and how do i fix it ?
Sep 17, 2010 | Nintendo Wii Console
I have 2 Peavey Impact 1015s and 2 PV 118 Subs. I have a Peavey Kosmos PRO that runs from my Numark CDMix3 to my amps. My two amps that I have are a Peavey CS800x and a Crest Audio CD3000. Could you tell...
Just a note regarding connecting: USE BALANCED lines everywhere you can. Use either XLR if available or TRS type cables. This will reduce noise pickup.
Another hint: For SAFETY of your equipment run ANY interconnected devices from the SAME power source. DO NOT say power the amps from one place and your other equipment from a different outlet. Afford a power distribution system that feeds from a single receptacle or nearby receptacles near a common electrical panel. This will ALSO help avoid noise as well as the hazards to your equipment from ground loops.
Apr 01, 2010 | Peavey Music
Motorola T5500 Scanning problem
Most likely it is stopping at a channel which has RF (radio frequency) activity. The activity doesn't have to be another radio with someone talking. It could simply be something transmitting on the same MHz. The only way to know for sure is to try the radios in a different location (as in moving away from the problem). If you want to avoid this "noise" you can turn on your interference eliminator, and it should block out anyone transmitting on the frequency (unless they set their interference eliminator to the same code as yours.)
If the noise continues when you try the radios in a different location (more than 5-10 miles away), then you will have to investigate a problem with the radios themselves.
Nov 09, 2008 | Radio Communications
Video Game Consoles & Games Logo
27 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
