Question about Car Audio & Video
I can't find which siriusxm vehicle tuner model that will work with my kvt 512. Hope someone knows
johnychel
  • 796 Answers
SOURCE: kvt-512 no sound when it
you must have changed something with the settings...
try to set everything to default settings....
wat is the model number??
Posted on Jun 22, 2008
  • 909 Answers
SOURCE: does anyone knows where to conect the dimmer wire
Connect to the side light live. So when you turn the lights on it dims the display.
Posted on Jun 15, 2009
  • 3 Answers
SOURCE: how can i get my kenwood kvt-512 or kvt-512
This is basically a hack. Type into the web address bar http://www.dvdhacks.co.uk/ enter model number then follow instructions
  • 23 Answers
SOURCE: Code set for a Kenwood KVT-512
Use KCAR for the code.
Posted on Aug 24, 2009
techman
  • 3130 Answers
SOURCE: I need the site for kenwood kvt-512 update
try this I use this for getting user manual or leave them a question Good Luck!!!!
Techman
http://www.kenwood.ca/Support
Posted on May 14, 2010
Chrysler 200 convertable how to put pictures on radio
SiriusXM Connect Vehicle Tuner - Shop - SiriusXM Radio
https://shop.siriusxm.com/xm/ctl10600/cp49759/.../c...
Sirius Satellite RadioMy Account. I'm a Subscriber ... Image 1 SiriusXM Connect Vehicle Tuner · Image 2 ... Add Satellite Radio to any SiriusXM-Ready™ car stereo receiver. Connect ...
[PDF]User Guide - SiriusXM
www.siriusxm.com/.../pdf/SkyDock_UserGuide.pdf
Sirius Satellite RadioThe XM SkyDock incorporates an XM Satellite Radio Tun- er . A special .... image to match the XM SkyDock's .... found on the My Account screen (in Settings), ... Button: Tap to tag the current song and add it to your tagged song list . For.
Dec 10, 2015 | 2011 Chrysler 200
How do i set up the sirius xm
This radio is SiriusXM *READY*. You will need to purchase and install the *optional* SiriusXM-Connect Vehicle Tuner kit (tuner, antenna, cables, hardware) specific to your radio - linked below:
SiriusXM Tuner:
SiriusXM SXV300v1 Connect Vehicle Tuner Kit for Satellite Radio
Manual (.pdf):
http://www.clarion.com/us/en/pdf/CZ702_Manual.pdf
Jun 11, 2015 | Clarion CZ702 Car CD/MP3 Player - 76 W RMS...
I have a Kenwood KVT-514 CD/DVD player that I just installed, But in getting no sound, The Radio works fine but when i try to you a cd or a dvd there is no audio. I've checked my connections seval times...
it sounds like you are using an amplifier. if so you are probably using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amplifier on. the power antenna remote wire turns off when leaving tuner mode.
Feb 17, 2011 | Kenwood KVT-512 Car DVD Player
I got a kenwood kvt-512 and my ipod seems like it doesnt work ?
go to :- http://kenwood.com/cs/ce/mm/firmware/2008/eng.html
then change the file to an iso and burn to a disc.
put the disc into stereo and press dvd and let the disc do the rest.
hope this helps works on all kvt systems
Dec 31, 2010 | Kenwood KVT-512 Car DVD Player
I need a wiring diagram for a kvt-910dvd
heres the manual to download, hope it helps
http://www.retrevo.com/support/Kenwood-KVT-512-Car-Videos-manual/id/13483ag924/t/2/
Apr 03, 2010 | Kenwood KVT-512 Car DVD Player
I need a wiring diagram for a 02-03 chrystler 300m i have a kenwood kvt 512
go to www.alldadadiy.com and get a subscription to your vehicle. I know you probably want a free link but this will turn out to be well worth it, you get every wire, color, connector, and location.
Feb 26, 2010 | Kenwood KVT-512 Car DVD Player
How do I change the background on my kenwood kvt-512
Check one DIY in this link: dyi-background-change-kvt-512-a.
Hope helps (remember to rate this answer.
Nov 18, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
How can i get my kenwood kvt-512 or kvt-512 multiregion player. it only plays region 1 dvds but how can i make it multeregion, thanx a lot
Jun 15, 2009 | Kenwood KVT-512 Car DVD Player
Does anyone knows where to conect the dimmer wire of a kenwood kvt-514 or kvt-512??
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
