What do you do when your tv said lan cable not connected
  • Paul Chapman
    Paul Chapman Dec 28, 2016
    Hi linda roesser, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
What do I connect the Lan cable to. Computer or T.V
never had a TV that had LAN connector on it
Dec 05, 2016 | Computers & Internet
Samsung smart tv
You have to connect a LAN cable in between your TV and router. There would be a LAN port on the back side of your smart TV and then you need to configure your network.
You can also use this video for more clarification. And can also visit our website for further technical assistance, i.e http://www.vtechsquad.com.
Apr 23, 2013 | Computers & Internet
Lan cable not connected
Try re-connecting the LAN cable to your computer and the model/router/
If this does not work the try a different LAN cable - the cable could be faulty.
May 02, 2012 | Sony VAIO E Series VPCEB36GX/BJ Notebook
When I use the wi-fi connection with the LAN cable provided and run the connection test, all of the tests are successful except for the Viera connection. It is saying the connection failed 006. How do I...
Viera has a set-top box in the TV and the lan wifi router can be connected to cable plant for internet. TV can also send out programs on the set-top box to other wifi receivers. Error code 006 is server failed, Panasonic had a fix on jan11, 2012.
Feb 11, 2012 | Computers & Internet
I have the Zyxel ES-105A connected in the following way: LAN cable from modum connected to port 1, LAN cable from port 2 connected to my laptop which I use to log in to my modum and LAN cable from port 3...
If your modem is not also a router you can only connect one device to it. You should have a router instead of a switch. Otherwise check the settings on your modem to be sure the ports are open that are needed for the Sling Catcher.
Apr 04, 2011 | Zyxel ES-105A (ES105A)
I don,t know how to use and connect lan connection for my lcd tv
you will need a cat5 cable, you can pick one up at radioshack or walmart.
plug this into the LAN port of your router and TV.
depending on the make/model of the TV it should be able to pick up a dhcp address and connect to the network/internet.
Feb 26, 2011 | Computers & Internet
How to hook up tv with internet hard wired to existing router with wireless connection to computer ip address on computer will not connect tv to internet help
Assuming that you have an "IP" TV, run an Ethernet cable from the TV to one of the LAN ports on the router.
Run another Ethernet cable from your computer to one of the other LAN ports on the router.
Both the TV and the computer should now have Internet access.
Do you have a third computer that has a "wireless" connection to the router?
Sep 26, 2010 | Belkin (F5D7230-4) Router (587009)
How do i set up the LAN connection?
try wireless lan... if u want wired one buy a hub(for many to one connections) ,lan wires of good quality and connect to the lan port of ur cpu.then connect the video cables to the tv...if the connection works u can find the indicater lamp litting in the hub.........
Apr 01, 2010 | Panasonic TH-46PZ80B 46 in. Plasma TV
What is the difference between wireless router and a LAN router?
You can a wireless router that does the same thing as a LAN router, but you may have a cable LAN router that doesn't host clients wirelessly.
The basic funtion of both is to correctly route network traffic for the intended recipient. The information can be from computer to computer or across intranets (normally high-end switches are used instead) or from the internet through a modem (modulator demodulator) to computers connected to the router (wirelesslor cable).
The difference being, the cable LAN router is connected by a ethernet cable and is capable of faster nominal transfer speeds and a wireless is able to transfer information across a 2.4GHz radio signal.
Don't knock the speed of the wifi, though. I quite happily stream movies from my server to my TV through a wireless connection.
May 10, 2009 | Edimax BR-6114Wg Router (BR6114WG)
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
