Question about Home Security
Is there a factory reset code for my sentury safe modelv260 , it wont lock with the 2 keys or my keypad. Any help is appreciated.
SOURCE: keypad lock with security code
u need to go to d nearest nokia service centre n tell dem d same...they will change ur security code n make u choose 1 for u....no need to panic...those pple will help u..!!
Posted on Aug 24, 2009
AldRezaine
  • 995 Answers
SOURCE: The keypad lock function has locked my phone. Need
The only for it is to take it to the authorized Nokia service center.
Posted on Nov 02, 2009
  • 27 Answers
SOURCE: i locked my keypad on my rival and forgot the code
call in
Posted on Nov 19, 2009
vijaydaniels
  • 94 Answers
SOURCE: nokia 3110c keypad lock forgotten
if you could get to settings menu and restore factory settings,your problem will be solved
Posted on Jan 13, 2010
SOURCE: I get a message Keypad is Locked Press Unlock Key
need to unlock keypad on phone please
Posted on Mar 03, 2011
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    My safe, a Cathedral EA15 Will not lock. Any suggestions people?
    Instructions
    1. 1
      Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
    2. 2
      Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
    Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
    1. 1
      Enter your code to open the safe.
    2. 2
      Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
    3. 3
      Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
    1. 1
      Use your code to open the electronic digital safe's door.
    2. 2
      Locate and remove the battery cover on the inside of the door.
    3. 3
      Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
    4. 4
      Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
    Feb 08, 2015 | Locks & Locksmithing
    How do i set code for paragon safe
    INITIAL BATTERY INSTALLATION
    1. Remove the key plate cover, insert the key into the keypad and open the door.
    2. Remove the battery cover plate located on the inside of the door.
    3. Install 4 AA batteries provided and replace the battery cover.
    NOTE
    : If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
    to be changed.
    TO SET UP OR CHANGE A USER CODE
    1. With the door open, locate the red button on the back of the door near the hinge.
    2. Press the red button and listen for the beep.
    3. Immediately enter your new passcode (3-6 digits long)
    4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
    NOTE:
    This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
    first passcode entered.
    SETTING UP OR CHANGING A MANAGER PASSCODE
    1. Open your safe with the passcode you wish to change and leave the door ajar.
    2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
    New user passcodes may be 3-6 digits long.
    3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
    OPENING THE SAFE
    1. Input your code and then press the "B" button, the green light will turn on.
    2. Turn the knob clockwise within 5 seconds to open the door.
    3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
    flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
    CAUTION
    : Entering the incorrect passcode 3 times will lock the system for 20 seconds.
    More information can be found in the attached document web page.
    http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
    Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
    Change code on Futura wall safe
    Refer this problem to Futura
    May 24, 2013 | Locks & Locksmithing
    I forgot the safewell electronic code and didnt have the key
    NOTE: The safe needs to be upright and right side up or the locking mechanism
    won’t work.
    ELECTRONIC SAFES
    To open an electronic safe the first time, press the following numbers/letters on the
    electronic keypad –159B. (These numbers are preset. You should change the code as soon
    as possible after opening the safe to insure proper security). After you have entered the
    factory set code, you will need to turn the knob on the faceplate to open the door. You will
    have 5 seconds to turn the knob before the locking mechanism is reactivated.
    ENTERING YOUR SECURITY CODE
    To enter your own security code you will need to follow the steps listed below:
    1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
    small red button on the inside of the door near the hinge.
    2. Press the red button and then release it, you will hear a beep.
    DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
    SECURITY CODE HAS BEEN ENTERED CORRECTLY.
    3. With the door open, enter your own personal security code, which can be 3- 8 digits
    long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
    Before you close the door, try the new security code to make sure the lock release the
    knob so you can turn it and retract the live action locking bolts.
    If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
    Good luck
    Sep 14, 2009 | Locks & Locksmithing
    Sentry S3807 safe-cannot open
    locksmiths agree on how to install sentury safe batteries
    slide open the battery cover located just below the keypad.
    Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
    reconnect the connector and put back the battery holder. Slide the cover back in place.
    How do I insert the batteries on my advanced electronic lock safe?
    to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
    Jan 26, 2009 | Sentry Fireproof Safe
    I cannot open my safe.
    try holding the # and the * key for 5 seconds that should reset the safe and open it up
    Dec 22, 2008 | Sentry Fireproof Safe
    Home Security Logo
    52 people viewed this question
    Top Home Security Experts
    Lawrence Oravetz
    Are you a Home Security Expert? Answer questions, earn points and help others
