Question about Frigidaire Kitchen Ranges
Frigidaire glass top stove Model FGES3065KFG. The whole stove top has died. None of the burners turn on.
aborcass
  • 2651 Answers
SOURCE: Burner no longer functions
two thiongs, you might have a bad switch( under control knob), or before you try that ck the old elemnt that you replaced, on the back of the limiter( the glass rod that goes through elemnt itlself), you'll see little letters 1a,2a,1b,2b.--- new replacemnets depending on age are wired differently, they too will have 1a2a1b2b but in different position. id check that first
Posted on Mar 03, 2008
  • 1073 Answers
SOURCE: hotpoint glass top stove
sound as if you only have 120 volts going to the range check the voltage
Posted on Apr 12, 2008
barkencoa
  • 3463 Answers
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
Posted on Dec 14, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
SOURCE: burner on glass stove top has turned black
The nice grey-flecked surface coating is very thin; the solid black is underneath. You've "cleaned" the coating off -- that's why further scrubbing just makes it worse. We did the same thing :-(
Posted on Apr 25, 2009
Top main burner want turn off
Switch is either bad in it or has food/grease build up not letting it shut off.
Unless its a newer model and is push button?
Nov 12, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
After replacing the front panel on my Frigidaire Mod. # FGES3065KFG the top elements are the only thing working.
Thanks for your inquiry, Harold Goodman!
I see that you replaced the front panel on your Frigidaire range, FGES3065KFG, and now the controls are not working. Sounds like it could be a possible problem within your EOC (Electronic Oven Control) or UIB (User Interface Board) I would seek assistance from a professional to come out and properly diagnose your range. This can help avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Kitchen Ranges
Replacing burner on slide in FES365ECA frigidaire stove
Good Afternoon Friend,
I understand you are trying to get assistance on how to access the burners on your glass-top Frigidaire range, model# FES365ECA. I suggest contacting the manufacturer. They might have some type of diagram that will assist you in replacing the burner. My other suggestion would be to contact your local authorized technician for further assistance. The technicians have been trained to replace parts on your range. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Frigidaire Kitchen Ranges
Frigidaire Glass Top Stove - Model #FEF668CJ5C The
Check your incoming power for 240 volts and your circuit breaker.
Check the cord where it attaches to the back of the range. If they are OK,look for a loose or broken wire.
There are no fuses in-line with the surface burners.
Jul 10, 2010 | GE JBP65 Electric Kitchen Range
None of my stove top burners will spark to ignite
There is an ignition module that sparks when it calls for lighting. This module could have a loose connection or be dead.
Apr 03, 2010 | Frigidaire PLEF398AC Electric Kitchen...
Broken glass top for my gas stove
You can buy just the glass for your glasstop stove. I too need to replace my glass...I have a whilpool electric glasstop. Its not cheap...may just buy new stove. I priced just the glass for my whilpool at the cheapest I can find for $320.00. Thats a lot. Mind you its not the elements under the glass..its just the glass! So...idk bout you, but a whole new stove might be my best option. If you want to price the glass for your model just keyword search your number and brand of stove and type replacement glass. GOODLUCK! :)
Feb 16, 2009 | Frigidaire FES367 Electric Kitchen Range
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Glass stove top has a piece that has peeled back
once they are broken they are broken you have to replace he whole top
Feb 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
Frigidaire smooth top stove
MY OVEN IS WORKING, THE STOVE TOP DOSEN'T. tHE CLOCK SHUTS OFF WHEN i TURN THE BURNER KNOB OFF AND WHEN i TURN ONE BURNER ON THE CLOCK FLASHES 12:00 AND THERE IS A SHORT BUZZER SOUND COMING FROM BEHIND THE PANEL. CAN I FIX THIS MYSELF?
Dec 16, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kitchen Ranges Logo
52 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
