Question about Water Water Heaters
I need to replace the pressure relief valve on my intertherm water heater model number HSE 30F-240S. are most universal? other than the size i.e.: 3/4, or 1/2, etc...
    Top Expert:
  • Water Master
  • 78,267 Answers
Yes they are a universal part, any good hardware store will have them, just bring the old one with you.
Posted on Dec 28, 2016
Testimonial: "Thanks a million!"
Does an Intertherm water heater model HSE 30F 240S have a dip tube? Cold water comes n on the side of the tank not on top or bottom.
How to Repair or Replace Defective Water Heater Dip Tubes
www.familyhandyman.com > Skills > Plumbing
The role of the dip tube is to direct incoming cold replacement water to the bottom of the tank for heating. While it warms, the dense, cold water stays naturally segregated from the warmer, lighter water floating on top. The water for faucets and appliances comes from the hot layer on top.
Jul 28, 2015 | Water Water Heaters
My pressure relief valve keeps blowing more so when it is hot any ideas please
Pressure relief valves open on high temperature as well as high pressure. They do go bad and are replaceable.
Consider calling the plumber. It is not very expensive part and the plumber can change it quickly.
If you just want to do it yourself:
  1. Write down the make and model of the water heater.
  2. Go to a real plumbing store and buy a new one.
  3. Turn off the heat source (the gas or electricity)
  4. Turn off the water inlet and open a hot water valve at any sink to take the pressure off the heater.
  5. Remove the old relief valve. It may take a long handled wrench.
  6. Install the new pressure relief.
  7. Close the sink valve.
  8. Turn on the water and check for leaks.
  9. Turn on the heat source.
Good luck.
Apr 11, 2015 | Water Heaters
Patricia bailey the product I asked question about is a inter therm 40 gal hot water heater model HSE-40F-240S
call a plumber to have the valve replaced is all you can do dear!!!!! to make hotter water you need to turn the thermostats up they are behind metal plates where the elements are .doing so will cost more money on electric bill
Feb 17, 2015 | Water Water Heaters
Pressure relief valve intermittent noise
check your water pressure and then make sure it is not to high or all the problems you have had were not the answer. it is a pressure /temperature valve not just . temp.
Apr 06, 2014 | RHEEM 40 GAL ELEC Water Heater 6YR SC...
Relief valve buzzing noise
Add an extrol expansion tank to the piping. You can get one for about thirty dollars from the hardware store.
Apr 06, 2014 | Rheem 82V40-2 Fury Electric Residential...
What is the cavity size for the relief valve that I need Model 22V50F1
TP valves screw into 3/4" opening.
End of probe MUST extend into upper part of tank, and cannot be located on pipe away from main body of heated water.
http://waterheatertimer.org/How-to-replace-TP-valve.html
Nov 10, 2012 | Rheem Water Heater Pressure Relief Valve
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    Hello, I need to replace a pressure valve on my on my water supply tank by my well. There is no high temperature in the system. Does this valve have one of those sticks that need space in the tank? ...
    Hello,This valve is pressure only.The model XL is pressure & tempature for a hot water storage/heater tank(has the stick).You need to know male or female thread and the relief # setting of the old one.The info is on the tag on the old one.
    Nov 17, 2010 | Watts 3/4 Pressure Relief Valve
    Leaking pressure relief valve
    what is the water pressure on the cold side? You may need to install a pressure reducing valve at the water heater inlet to reduce inlet pressure and keep pop off valve from opening when not needed.
    Feb 27, 2010 | Emerson Part UWL Chrome Ultrasystem water...
    Water Heaters Logo
    48 people viewed this question
    Top Water Heaters Experts
    vince
    80stech
    D. E. Hev
    Are you a Water Heater Expert? Answer questions, earn points and help others
