Hi, i buy two prontotec wimo C72R 4GB, for my kids...two months after i have two bkicked devices... i dont found anywhere the firmware to flash my tablets, you can help me?
The serial number on the mother board is M755_V1.41_4 2014-07-10
pastorm
  • 98 Answers
SOURCE: invalid electronic serial number
The PC serial number should be on a white bar code sticker on the back of the unit. Look for a sticker on the computer case.
Posted on Nov 27, 2007
mrsno
  • 166 Answers
SOURCE: sata drivers for my mother board
Hello there.
Click here to download drivers for your Intel based motherboard.
You need to choose your version of Windows from the list to continue.
Hope this helps.
Posted on Jul 19, 2008
  • 81 Answers
SOURCE: PROBLEM WITH AUDIO DEVICE
the front port wire is not connected to the mother board.please refix it .
Posted on Jan 14, 2009
  • 22 Answers
SOURCE: ERROR message "A Supported Tablet was not found on the system"
I have encountered this message a few times, usually if I have tried to plug'n'play the tablet. A restart with the tablet connected usually fixes it for me, but I would suggest removing the driver and software and reinstalling them, making sure you have the most up-to-date version- freely available from wacom.co.uk (though I note you have the latest versions so just reinstall those).
I think, however, your problem might be something to do with the following note from wacom:771c281.png Do you know if you are running a 64-bit setup? There may be a workaround even if you are, so do let us know.
Posted on Oct 29, 2009
  • 7 Answers
SOURCE: I have Sandisk USB 4G
which OS u r using? XP,Vista and 7 Os will automatically install the drivers for it.
if not, check sandisk site for drivers
Posted on Sep 06, 2010
How do I fix a pushed in charger port on a pink kids Prontotec Wimo tablet?
unless you know how to open the case I would take it to a computer repair shop .
Oct 28, 2015 | ProntoTec Tablets & eReaders
How do i get my prontotec 7 android 4.4 kitkat tablet pc cortex xA8 1.2 GHz dual core prosesor 512 MB/4GB to reset?
Reset
You can reset if you do a hard
reset.
follow this procedure.
1. switch the tab off. after,
2. long press power button +
volume down key simultaneously.
3. after it shows the logo then
release the power button but
continue pressing the volume key
until the wipe or reset menu
appears.
after that you can reset/wipe it.
May 23, 2015 | ProntoTec Tablets & eReaders
Read-only files and how to them?
Possibility
Firmware flash drive corrupted (the disk is write protected).
Solution
To repair damage to the firmware, the solution can be found on google seach engines. Example; Fix transcend flash drive, Fix sandisk flash drive, Fix PQI flash drive, etc.
Dec 15, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
SanDisk 2GB microSD Memory Card not working
SaveMyUsb.com can recover data from most flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 18, 2010 | SanDisk 2GB microSD Memory Card
How can i convert 4GB pendrive to 8GB ...?
can i convert the 4gb pendrive to 8gb..?
this is because the mc used in both are same, how to change default firmware installed in mc that flashes and make mc to increase its intensity of storage...if any1 kno..pls tell me da process..
Aug 19, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Sandisk cruiser micro 4gb flashdrive repair
Your best bet is to contact the vendor you purchased it from first, and many are good about replacements in the first 12 months. If that doesn't pan out, contact SanDisk directly at 1-866-726-3475 .
Feb 16, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My mp3 player wont start
You can try to reset the device by pressing the power button for about 15 to 20 seconds and aslo i would recommend you to get the firmware upgrade for your device..to get the firmware upgrade please follow the link below...
http://support.rcaaudiovideo.com/downloads.aspx?product=384
I hope this helps
Thank you
Computerrep
***Please rate accordingly..
Jan 30, 2008 | RCA Lyra RD1072 MP3 Player
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
