How do I fix blink blue light on blue tooth headphones
5 Suggested Answers
justaplumber
  • 98 Answers
SOURCE: dont know how to work my blue tooth to my phone
You have to get the phone to recognise the bluetooth headset first. The manual should tell you how to do this. Normally you have to go into the bluetooth menu on the phone and get the phone to detect the headset, and then type in the pin code, normally 0000.
Posted on Jan 11, 2008
  • 77 Answers
SOURCE: blue tooth adapter
Connect the headphones to the bluetooth.
Open the control panel, go to Sounds and Audio Devices.
Click the Audio tab.
Under Sound Playback (top portion of the tab), it says 'Default Device'. Drop the menu down and select your headphones. Click apply then ok, and you should be good to go.
I can't guarantee that this will stay set up this way. If you disconnect the headphones, you very well may have to run through this again.
Posted on May 06, 2008
  • 1745 Answers
SOURCE: Cannot establish blue tooth connection to ipad
try to turn on BT on iPad while Logitech is blinking (which means it in pairing mode and can be discovered). If that doesn't help I'd suggest to remove batteries from Logitech for 3-5 minutes then put them back.
Posted on Feb 09, 2015
  • 43059 Answers
SOURCE: Trying to figure out why my olive blue tooth headphones won't charge. The red light continue to blink but not charging
usually a sign the batteries need replaced .
Posted on Sep 27, 2016
What if my uproar wireless headphones are flashing red and blue ?
The headphones flash blue when u switch it on.If it flashes blue and red, it means that it is in bluetooth connection mode.So u can connect it with bluetooth devices by switching on bluetooth on your phone or pc.After connecting the red light stops flashing automatically and blue light starts blinking.Hope you understood. :)
May 04, 2016 | Audio Players & Recorders
My p.c does not get any drivers for my sansui bluetooth headphones.
If you have other blue tooth devices working correctly, do a search for new devices on your blue tooth software. Pair the headphones using the blue tooth software.
Jul 15, 2015 | Audio Players & Recorders
Can I connect to Vizio TV with blue tooth
If your ear buds have been connected to any device before your TV then it won't work. If you want to connect it to your TV you turn on your headphones, hold the call button for 3 seconds, and you will see ur light flash and connect it to your TV. If this didn't help then go to the manual and check how to connect your headphones to your TV.
May 24, 2014 | AUVIO Bluetooth Headphones
How do I hook up my blue tooth headphones to my onkyo SR 605
You cannot rig up a blue tooth headphones to this receiver with out a blue tooth transmitter ( the Onkyo does not have one built in ). If you have a transmitter it can be plugged into the headphone out socket of the Onkyo ( in front ), just remember that it will cut out the sound from all your speakers when you insert the headphone jack . The advantage though with this connection is you can control the headphone volume using the Onkyo remote.
Mar 12, 2011 | Onkyo TX-DS656 Receiver
How you play music on jabara bt 2050 0n phone
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
Feb 25, 2011 | Samsung Radio Communications
How to reset bluedio av890
Switch it off.
Press the on off switch for little long duration, till the Light glows steady/permanent (without blinking).
At this stage it can be connected to a device enabled with Blue tooth in "switched on" condition using the passcode "0000" (four times zero)
MUTHUPETCHI V (muthupetchi008@gmail.com)
Apr 15, 2010 | GE ON-SHLDR BLUTOOTH HDSET Wireless...
Blue tooth adapter
Apr 27, 2008 | Computers & Internet
Transmitter not turning off or reseting.
is this a blue tooth headphone..if yes...if it is, hold down the power button until the led rapidly flashes and then relase the button
Mar 19, 2008 | Logitech (980361-0403) Headphones
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
27 people viewed this question
 Grubhead
Grubhead
