The door on the washer is stack, it doesn't want to open. What can i do?
Did you try unplugging, wait about 15 - 20 seconds then plug back up and power on.
Posted on Dec 28, 2016
Testimonial: "Thank you for your advice, we did, nothing happened"
  • 2,913 Answers
Probable problem is the door safety catch is still engaged. This would usually release a minute or two after the end of a programme or when the power is switched off. Removing the top of the machine should provide access for a closer examination.
My kenmore 98702 stacked washer/dryer washer lid does not stay open
Underneath the top unit (the dryer) there should be a spring loaded catch that holds the door open. See if it is gummed up and stuck or possibly broken off.
May 29, 2014 | Kenmore 98702 Stacked Washer/Dryer
How do i replace a stack washer dryer dryer door switch?
when you open washer door you hit a stopper pin that holds the door open. there are 2 screws located around that area on both sides of panel. remove them and you'll see vent hook up and water line hook up and power cord. Now at the backside of washer door panel there are two screws remove them and pull washer door panel towards you. under the door panel connected to panel is where you will find door switch. if you jump out door switch and it works then you need new door switch.
Apr 30, 2014 | Whirlpool Thin Twin Washer and Electric...
I know it takes 2 minutes to start, but my washer doesn't catch when you close the door, it takes about one hundred times for me to open and close the door until it actually catches and goes into...
I suspect a lid switch. Go here for your model and help
http://appliancehelponline.com/index.html
Please rate me thumbs up and testimonial, if this helps
Thanks
Leo Ponder
imufo2
Aug 16, 2011 | Whirlpool LTG6234D Front Load Stacked...
Maytag Model MLE2000AZW stacked washer/dryer....washer door is locked; how can it be unlocked?
take the two screws off the panel between the control area and washer door. at the left end there a peice of green plastic like twine. take that out and pull to the left. while doing so open the door.
Apr 27, 2010 | Washing Machines
My washer and dryer will not come on what is wrong
Check the door limit switch/s. all power goes through the limit switches first.Assuming the power to your plug is correct.
Sep 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Sour smell coming from washer even when door is
If you have a front loader it will hold water around the seal of the door and after time it will mold and start to smell.
Jun 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
The door on my dryer and washer open the wrong way
Are you planning to reverse the door swing direction on your
DUET®dryer? To do so, you will need to purchase a Door
Reversal Kit.
To order, call the dealer from whom you purchased your dryer or
refer to the "Assistance or Service" section of this manual. Ask
for Part Number 8530069 (Shield Blue), 8530070 (Shield
Platinum), 8530071 (Biscuit) or 8530072 (Pewter).
Door Reversal and Stack Combination Kit
® ® DUET dryer and stack your DUET washer and dryer? To do so,
you can purchase a Door Reversal and Stack Combination Kit.
for Part Number 8530073 (Shield Blue), 8530074 (Shield
Platinum), 8530075 (Biscuit) or 8530076 (Pewter).
From the manual, Page 4. Hope this helps
Eric
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0802161.pdf
May 24, 2009 | Whirlpool Dryers
Is door reversible on duet model GHW9100LW1
The technician informed that we cannot reverse the door on the washer.
Apr 09, 2009 | Whirlpool Washing Machines
Dryer door
I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
Aug 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Maytag stacked washer/dryer
CHECK THE DOOR SWITCH TO SEE IF THE WIRE ARE CONNECT CORRECTLY. ON THE SWITCH THE WIRE FROM THE BULB SHOULD GO TO N/O IF ALL WIRES ARE CORRECT .THEN YOU NEED TO REPLACE THE DOOR SWITCH
Jan 03, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
