Question about Maytag Kitchen Ranges
I have a maytag gemini black glass top electric stove with a white clouding over one burner that we cant clean away....any suggestions????
jsrock516
  • 5911 Answers
SOURCE: Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Posted on Aug 04, 2007
  • 409 Answers
SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Posted on Oct 25, 2008
  • 105 Answers
SOURCE: Maytag Electric Ceramic Glass top stove
You can replace the failed component which is either the burner or the switch that controls the burner. A voltage test would have to be done to determine which compoonent has failed. Generaally it is worthwhile to repair the range.
Posted on Apr 08, 2009
SOURCE: burner on glass stove top has turned black
The nice grey-flecked surface coating is very thin; the solid black is underneath. You've "cleaned" the coating off -- that's why further scrubbing just makes it worse. We did the same thing :-(
Posted on Apr 25, 2009
SOURCE: Maytag gemini schott ceran stove top
Princess House offers a ceramic top cleaner that includes sulphuric acid. Using it, I have removed at least half the scars from burning food onto my schott cerami cooktop.
Unfortunately, some stains are more accurately pits...which it seems can not be resurfaced, but effect the cooking very little.
Princess House is a 'party' company, like amway. I imagine a Google will stear you in the right direction.
Posted on Jun 04, 2009
Cant find the model number for a maytag gemini double oven with ceramic cooktop. Any advise?
On the Maytag Gemini Series Double Electric Oven, the Model and Serial number is located on a flip-up metal plate/tag which is located on the upper left side/rear of the of the control panel. There is no need to move the stove away from the wall. Simply place your fingers over the top left edge of the control panel and flip the metal plate/tag up from a point just left of the control panel's center and flip it to the left (it's hinged on a screw to the far left of the flip-up plate/tag).
Dec 30, 2012 | Kitchen Ranges
Can a glass top be replaced on a Maytag electric stove?
yes you can Check with AppliancePartsPros.com. You might save 50 or sometimes as much as 250 on a new glass top. They won t even charge you extra for shipping
Oct 17, 2011 | Maytag MER6769 Gemini Electric Kitchen...
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Back burner doesn't work looking to remove and
These burners are very simple to replace. Is yours a glass top or does it have coil elements on the top of your stove?
Either way, we can direct and guide you to complete this repair.
You will need to contact us with your model number and we can tell you exactly how to remove and replace the element. When you get your parts from us, here at Accurate Appliance & Parts Supplies, we send complete instructions when when we send the parts to you.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST Monday through Saturday.
We hope to get you cooking again soon and look forward to working with you. Thanks, Ella
Nov 21, 2009 | Maytag Gemini 30" Self-Cleaning...
Apr 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Burner on glass stove top has turned black
Dec 06, 2008 | Maytag MER5770 Electric Kitchen Range
How do i clean the top of my gemini stove
Use Baking Soda and water and form a paste. Use this to clean the top of your stove. If food is really baked on, you might also consider using a single blade razor to scrape the mess off. Rinse well.
Sep 21, 2008 | Maytag MER6772 Gemini Electric Kitchen...
I have problems cleaning black Gemini stove top
How do I clean the top around burners?
Jul 16, 2008 | Maytag Kitchen Ranges
Top of Gemini range
Hello patricialc,
Welcome,
You said, you have the stainless Gemini range and the top is black. I cannot get the top clean. It looks like the paint or the surface is "bubbled". I have tried EVERYTHING and it always looks like there is grease spatters on the top. I have all Maytag appliances and I am VERY disappointed with this stove. If I could, I would take it back...but I keep trying. I let the Maytag stove I had go. It was made in the late '50's, so I could 'update'. What a mistake!!!
The other option is to order a new glass top and have it replaced.
No abrasives!!
Let me know how you do.
Huuum
Please remember to leave a rating!
Jun 29, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag MER6772 Gemini ELectric Stove
F9-3 code means the latch on the oven is faulty. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=MER6772BAQ&PartCategoryName=&Keywords=latch
Sep 17, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
Top Maytag Kitchen Ranges Experts
vince
Sal De GO PATS
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
