I did the set up but keeps shutting off. Is there a button I push?
How do I fix my TV when it keeps turning itself off, every 7 8 seconds?
you've possibly pressed sleep mode or some other timer setting, refer to manual and select "restore factory settings"
Dec 19, 2014 | Televison & Video
Power button lock icon keeps popping up on screen. tried to push reuird buttons to fix. buttons on monitor are not working properly.
Push and hold your monitor's POWER button until the monitor shuts off completely.
After it is shut off, press the POWER button again to turn it back on and the lock should be disabled.
Sep 04, 2011 | ViewSonic Va2431wm LCD Monitor
How do you change your password on a youniverse keep safe diary
You push the reset button on back under the batteries pannel if you dont remember the password. Then after that (or if u just want to change your password, open the dairy, push the change password button, while diary is still open type in your new desired password then simply, press the change password button again and shut the diary. You are now all set
Jan 29, 2011 | Toys
I need to reset my tascame to its origanal factory settings
You will lose all your data. Here are the instructions:
Turn off your unit, push down on the following buttons; Quick Routing, Shift, Sendand Shut Down button. Keep all these buttons down at the same time and keep them down while you turn on the power button to boot up the unit. You will see the changes being made as the unit boots up. Good Luck!
Nov 05, 2009 | Tascam 2488 Portastudio Multitrack...
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
On off on my 32 inch rca
Bad tactil switch behind buttons or possible bad solder connects
in microprcessor circuit............Sounds like an odd problem....T.
Nov 07, 2007 | RCA F32450 32" TV
My TV keeps shutting off
Tvtek is on the right track. The remote will not solve the problem. Sounds like a voltage regulator in HV circuit if it only lasts a few seconds. If it stays on for a couple of minutes, beam limiter cicuit is pushing to overload and shutting unit down. Magnavox set not hard to repair, but a 27" set is not cost effective to repair either.
Jun 06, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
