Question about Emerson Televison & Video
I have aan older Emerson VHS/DVD player no remote and I want to play a double feature movie and can't get to the second movie. How do I get the second movie to play?
Benimur
  • 6966 Answers
SOURCE: dvd player is not working
You need to switch on/off your  Progressive Scan (Pscan) mode. This may be in your remote or a small switch at the back of the DVD player.
Good luck and kind regards.
Posted on Oct 21, 2007
SOURCE: My Sanyo DWM-400 plays some DVD's and won't play others.
I bought another DVD player. I found out that all DVD's don't play on all DVD brands of players. They are cheap enough these days so I decided it wasn't worth a repair bill. The Sanyo DWM-400 plays many of my store bought DVD's and not others. I never tried a home made DVD in it so I don't know how it responds.
Posted on Jun 26, 2008
SOURCE: Multi region code for my DVD player
open draw
press '0' 3 times
press which region (Eg 0 for multi)
press pause
and whola!!!
Posted on Jan 06, 2009
  • 106 Answers
SOURCE: dvd stuck in player
  • unplug the system then take the screws out from bottom and try to open the whole thing then you will not only get the dvd out, you can clean the lens with a Q-tip and rubbing alcohol. or unplug then plug back in and see if dvd comes out after plugging in.
Posted on Mar 26, 2009
welcomejee
  • 10594 Answers
SOURCE: VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
Posted on Apr 16, 2009
How do I play the second movie on a double feature dvd disc?
Hi Tia, put the disk in and when the main menu comes up select the movie you want.
Apr 03, 2018 | Televison & Video
Green tint on TV screen when playing DVD's or Videos 2nd problem and can't record anything
1: Hi i would recommend trying the recorder on a different tv to check if the problem continues. If the green tint is gone then its the tvs inputs. If it is still green then its the player or the cord. Try a different cord if the green tint is still there then the player has a problem.
2: Now for the VHS to DVD. There are general a lock out encoded on the VHS if it is a store bought movie. This is to protect the content on the VHS from piracy and that would case the DVD to be blank. The VHS to DVD are made for converting your home videos like family vacations and stuff you record your self and not for commercial movies like the ones you bye at the store. If you want to convert old VHS movies to DVD you would have to get another VHS player and another device in between the VHS player and the VHS to DVD recorder.
Mar 19, 2014 | Televison & Video
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
My dvd/vhs player has stopped playing dvds. The light goes on when I switch it to dvd put instead of playing the disk it switches back to vhs. It will play vhs tapes. My TV is an Emerson LC320 EMX and...
The dvd player has lost ability to focus on disks and will not play them. It needs to be replaced. Check it out - if it is not proprietary and appears to be a unit like what you have in a desktop computer you can try putting one of those in there.
Aug 27, 2017 | Televison & Video
I lost my Emerson remote for my RWI-R dvd/vhs combo. How can I dub my VHS movies?
Buy a cheap universal remote.To my knowledge you can only use one or the other.In other words you can't copy form the DVD to the VHS on the same machine
Sep 28, 2009 | Emerson EWH100F
Won't play homemade movie
It's the dvd player. I tested it on another and it worked fine. Guess I need to replace the old Emerson with a new one ;o)
Dec 27, 2008 | Emerson EWD7002 DVD Player
Panasonic Double feature DVD/VHS deck. DVD player not working. Inserted disc, pressed play. Says, "Reading" then cuts to blue screen.
We could not turn on the Panasonic Double Feature by remote or by manual. It is dead no power going in. What is the problem and how can we fix it?
Oct 12, 2008 | Televison & Video
Progressive scan mode will not disable
Hi, you must hold 1st remove the disc (if you have one in) then hold down the STOP which is just under the RECORD button. Hold it for about 6 to 8 seconds. That should clear it.
Good luck
trestaris
Dec 09, 2007 | Zenith ZHX-313 System
No playback
The dvd player does not recognize discs above 2x. I contacted Emerson, they have a software upgrade they will send you for free, but you have to ask for it. I think it gives the player the ability to read up to 8x.
Aug 15, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Televison & Video Logo
18 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
