Question about Toto Home
What would cause the toto tel3dsc to have excess battery useage while working normally
Loose seat,piece missing or broken
Hello, I experienced similar symptoms with my Neorest 600. Do not call a plumber, they cannot fix!
I recommend calling Toto! Their support people will take the time to help you [this is what the experienced Toto plumber did that I hired :' ]
I had a leak too and ended up sending the whole electronics & seat in for repair. These one piece units do not require a plumber. Lo [Toto technical support] gave directions that I, a 60 year old woman who normally does not disassemble such an item was able to perform!
I realize some may not like my post to turn it to the manufacturer, but in this case it was the best solution for my fix.
Call first, get a case number and support person. Then they work quickly via email with you. This was my only toliet :' So i was with out a toilet during this period. Toto worked quickly to get my toilet back to me! The shipping time is what took the longest. Take a photo of the problem and you will be able to submit for your case via online.
Hope this helps! And hope your fix they will be able to send parts for so you are able to fix!
My excellent contact.
Lo Lam
Senior Technical Support
Technical Support
(888) 295-8134 ext. 1641Office
(888) 295-8134 ext. 4Tech Support
(678) 466-1287Fax
TOTO USA,Inc.
5351 Jurupa StreetOntario CA, 91761
http://www.totousa.com
May 29, 2014 | Toto MS990CGR11 Neorest 600 One-Piece...
Toilet Problems: One has Noisy flush & two others drip at rate of about two drips per second
Do you have a way to check your water pressure each of these problems could be caused by excessive pressure you may need to install pressure adjustment valve if you can't find another way
Jun 10, 2017 | Toto Home
Used 3.5 quarts of oil in 4000 miles
that is still within the factory spec for normal oil useage. one quart every 750 is considered excessive, i do agree that it should be less, but if this is a warranty issue u are out of luck, they won't do anything.
Sep 02, 2010 | 2005 Chevrolet Uplander
Toto i piece toilet 6 ltr. water leaking to lower bowl replaced flapper, tightened tank drain works fine for a short period. Should I be purchasing a manufacting flapper Tom C
Yes, for many toilets you need to get the exact flapper to make them seal properly...the generic will often not work properly..
heatman101
Aug 04, 2010 | Toto UltraMax One Piece Toilet, 1.6 GPF -...
Water continues to drip into overflow tube after fill
This is normal, though not so if it is excessive. Try adjusting the fill valve (there is either a ballcock or a float that surrounds the fill valve). With the ballcock, there is a screw at the top of the fill valve to lower the arm, on the other there is a metal clip to pinch and move the float with a large plastic screw for fine tuning.
Jun 26, 2009 | Toto Toilets ST784S 12 Sedona Beige...
Toto Drake ADA: Usual rush of water on flushing doesn't happen
Problem solved.  Reason was a totally blocked waste line that resulted in toilet malfunction.  Toilet functions normally now with removal of blockage.
Dec 27, 2008 | Toto Drake ADA Compliant Toilet with...
My toto toilet keeps running
if its a metal arm connecting the ballcock shut off valve to the float flush it and bend the metal so the float is lower. if u can adjust the ball **** lower then do so. the shut off is not shutting off cause the float isnt going high enough. and the excess is going down the overflow.
Nov 29, 2008 | Home
Home Logo
48 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
