I need a new door seal for dishlex silencio 855. I need a price & outlet to buy from. Do I need an expert to fit it?
    Top Expert:
  • Washing Mach... Master
  • 76,846 Answers
Dishlex dx 403
The seal at the bottom of the door is a splash seal only. The only seal that does the real work is the big thick one around the sides and top.
That said, you can buy them from your electrolux parts shop.
If in Aus you call 131350 for the closest one.
It is easy to fix yourself, just unscrew the little screws around the inner edge of the door to remove the front panel. Do this while door is still on, you do not remove the whole door.
Also, be careful not to cut yourself. The inner and outer panel edges are extremely sharp.
Jan 19, 2014 | Dishwashers
Brake vaccum pump seal leak
have they said were the leak is, as if it is the connector you can replace the seal for the pipe. failing that you will need a replacement, there are plenty on the market you can choose from, or even get one from a breakers yard for a good price. just remember to flush. out all the old brake fluid after you have fitted the replacement there is a kit you can buy that will push the old fluid out. and then put new fluid in. the kit will help you do this to.
May 02, 2013 | 2007 Volkswagen Jetta 2.5 Sedan
Where can I buy Caroma outlet seals?
Take the existing part to Lowes or Home Depot and look at there universal
toilet replacement parts. I bet you can find one that will fit.
Jan 04, 2013 | Caroma CARAVELLE270ADAW-EL Caravelle...
I HAVE A WASHERDRYER COMBO HWD1000 AND THE RUBBER GASKET RING IS BROKEN IT S LEAKING FROM THE FRONT DOOR WHAT PART SHOULD I GET?
hi the part you need is called a door seal you can order a new one on line from espares just type in washer parts you will see www.espares .co.uk click on it and it will have all the makes of machines come up click on your make and then click door parts put in your model number and it will come up with the door seal and the price with buy options to fit it its a bit tricky but easy if you need any futher help let me know
Nov 23, 2011 | Washing Machines
How to replace the door seal on a Simpson Silencio 850 Dishwasher Model No. 82B850WH. The part No. that I have for the door seal is 0208400158G & is Electrolux part number
The around the tank seal just pushes into the groove. make sure that you copy the way the old one comes out. The bottom of the door seal is a bit awkward. Thsi has some screws that are difficult to access. Take the door liner off and possibly two of the hinge screws so that the door can swing up at the bottom to allow easy access to the screws. You might get someone to help ny holding the door while you do this. Check tah the new seal fits the same way as the old one comes out. Then reassemble
Aug 01, 2010 | Dishwashers
Leaking dishwasher simpon silencio 850. not alot of water 100mls or so. can't see where it is leaking from, there are some water marks on the front right underside.
Commonly leak from door seal- check seal for rips, notches. Also common to leak from the black retainer that the door seal sits it-remove the seal (they just pull off) and shine a torch from inside the dishwasher around the back of the seal retainer, and see if there are any gaps around the outside of the seal retainer. Repair with silicone sealant if any gaps. Other things to check- check the screws that hold the top basket runner on are tight- there are two holes in the runners, move runner until you can see screw, check they are tight. Also check water level is not too high inside machine whenits running- there are three vertical lines on the bottom spray arm support tube- water level should not be above top line. If still leaking, call in the experts!! Good luck!!
Mar 13, 2010 | Dishwashers
Replace bottom door seal on Dishlex Global 300 Dishwasher - Model DX300SA
HI - i just replaced the bottom seal yesterday. The guy at the spares shop advised me to replace both (bottom of door and bigger seal ) at the same time to ensure no leaks - i did that. The bottom door seal come out when you unscrew the screws - (No need to remove door) and because of all the gunk (from years of washing and age of the rubber) i had to wedge a blunt knife in between (starting at one of the ends) and lever it out - MAKE SURE YOU TAKE NOTE OF THE WAY IT IS BEFORE YOU REMOVE IT! An easy way to remember is there is a nick in the rubber of the old (and new) seal and as it is not centred, just note if the nick is closer to the left or right of the machine, I have replaced mine and there is a little leak and now i wonder if i put the seal in upside down! it has to go in the same way - before you gimmy your's out can you tell me if the nick in the rubber is to the left or right? (LIZ at yodelayeeoo@gmail.com) If I have put in back right there is a chance the screw didn't go through the plastic part of the seal and therefore not holding it in place properly. GOOD LUCK! Don't worry about having to really work at getting the old seal out - you don't need it anymore and i didn't damage mine, regards, Liz
Jun 15, 2008 | Dishwashers
Bosch sgs43a32uk/01 dishwasher
clean filter outlet, pipe is ok ..remove stainless steal screws in side door it should be easy to fit seal then.
Nov 27, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Tank is leaking
Is it the tank or just the door seals? Ours was leaking recently, there was an obvious tear in the door seal. Once fixed no probs.
Nov 02, 2007 | Electrolux 23 in. ESL624 Built-in...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
