Question about GE Kitchen Ranges
We have a GE CAFE bottom and top oven. We have replaced the electronic igniter twice in the last two months and it has broke again... what could. Keep causing this?
    Top Expert:
  • GE Master
  • 78,257 Answers
Bad luck, poor quality replacement part? No telling.
Posted on Dec 28, 2016
Ge cafe stove bottom oven not working
Is there 120V to the igniter? If the voltage is there, but it is not glowing, replace the igniter... GE Range Stove Oven Igniter WB2X9998
Jan 02, 2016 | GE Cafe CGS990SETSS 30" Free-Standing Gas...
Handle broke off microwave
lLAST TIME MY GE MICRO HANDLE BROKE IT WAS 179 FOR REPAIR
IT BROKE AGAIN AT THE TOP
AS ITS TEN YEARS OLD I JUST PUT CRAZY GLUE AT THE TOP AND THEN TOOK AN OLD RUBBER HANDLE FROM A CAN OPENER AND TAPED IT WITH ELECTRICAL TAPE TO THE INSIDE TOP OF THE HANDLE THIS WAY THE HANDLE CAN ONLY BE OPENED FROM THE BOTTOM NEXT I WILL TRY TO GLUE THE CAN OPENER HANDLE TO THE BACK OF THE MICRO HANDLE AND REMOVE THE TAPE
Jan 28, 2012 | GE Advantium 120 Convection/Microwave Oven
CGS980SEM1SS GE Cafe gas range which is 2 yrs 2 mths old. Oven shuts off after 5 mins, 10 mins, 20 mins...and at any temperature. All control panel functions cease to work, and most of the times the stove...
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then 1120 ohms then it should be replaced however, if it reads between 1080-1120 ohm then check the control and door switch and replace the part that is bad. You can also check the wire harness from the control to the electronic board. Hope this helps...
Daniel
Feb 11, 2011 | GE Cafe CGS980S Kitchen Range
I had problem with the GE Profile Spectra JGBP90 Gas Kitchen Range try to turn the stoe on , clicking noice but no flame. smell lots of gas. how can I light the pilot light back, where is it?
This range doesn't have a pilot,it has an electronic igniter. If you are smelling gas while trying to light, your igniter is bad and needs to be replaced. Remove the racks from the oven. Remove bottom panel in the oven. Remove the metal plate that covers the flame spreader. The igniter will now be visible. Try turning on the oven again. Take note of how bright the igniter gets. If it stays a orangish color it needs to be replaced. It needs to get to an almost bright white,
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven shuts off while baking. No error code, it just shuts off and none of the buttons work on the GE Cafe range.
I have the same problem. GE repair man replaced the electronic control panel. If anything, the problem is worse. Does anyone know what ACTUALLY makes this range shut off as it gets up to temperature while baking? I don't really want to pay the repair man to fumble around debugging this.
Aug 24, 2010 | GE Cafe CGS980S Kitchen Range
Oven not working
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jan 06, 2010 | GE Cafe CGS980S Kitchen Range
Same Problem Twice
Yes, the card should last longer. You should verfiy that your electrical voltage is appropriate, and also make sure the unit is grounded properly. Voltage spikes can and do burn out electronics, you may also want to consider install a surge supression system on your electrical system
Jul 09, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Gaggenau EB 194 Double Oven fuse blowing
from your description, it seems the little fuse is overheating sometimes, a short is a short and an immidiate fuse blower. i would use a higher amperage fuse, 30 amps. any electronic tech can replace this, doesnt have to be your Gaggenau guy, as it seems to me hes made a regular income of this
Apr 17, 2009 | Gaggenau EB294/295 Electric Double Oven
Overlay Panel bubbles up!
I had the same oven panel overlay bubbling problem on my GE oven purchased in 2008. It started peeling and bubbling within the 1 yr warranty, and GE sent me a replacement panel. This new part began bubbling again within 4 months. Again, I called but now they say it's out of warranty and they will not replace it. Obviously there's a manufacturing defect in this part. The panel looks terrible. It appears that GE no longer cares about the quality of their products.
Jan 02, 2009 | Ovens
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
