Question about Garmin GPS
My garmin will not power on - Garmin GPS
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Garmin Expert
  • 186 Answers
Plug your GPS into a usb charger overnight. If it does not power on after that, you likely need to change the battery. Amazon sells battery kits for Garmin.
Posted on Apr 10, 2017
I can't get my garmin 770lm to power on
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. If the GPS does not power on (it should go into usb mode), then contact Garmin for warranty work. You can also check the power adapter in your vehicle. If the red light does not come on, the adapter either has a blown fuse or went bad, causing your GPS battery to be discharged.
Apr 01, 2017 | Garmin GPS
How do i program the garmin to automatically turn off when my car turns off?
There are two ways to do this:
The first is to have the Garmin connected to a power source that is only on when the car is on. When the Garmin looses power, it will warn you and wait a few seconds, then power off.
The second is to purchase the Garmin EcoBoost module so that your GPS can detect when the car shuts off. Your Garmin has to be EcoBoost compatable to use this second solution.
Oct 04, 2014 | Garmin nuvi GPS
Nuvi will not turn on
What model Garmin Nuvi ???....
On occasion, your Garmin GPS may experience technical malfunctions, including failing to power up.
When this happens, perform a manual hard reset of the unit.
A soft reset entails holding the power button until the unit powers down, and then pressing the it again to power the device back up.
However, when the unit won't turn on, a soft reset won't work. In this case, a hard reset is the only way to get the device up and running again.
Unplug power and USB cables to disconnect all sources of power to the unit.
Place your thumbnail into the groove located below the Garmin logo on the face of the unit.
Pry the faceplate off using gentle pressure.
Press the reset button and hold for approximately 3 seconds.
When the device is facing you, the reset button is located in the middle of the right-hand side of the front of the device.
Snap the faceplate back into place.
Press the power button.
Your GPS should now turn back on.
Garmin Nuvi With No Power
A Garmin Nuvi is a type of GPS device that can help you find your way around when traveling by motor vehicle.
You can mount the Garmin Nuvi inside the windshield of your vehicle and allow it to acquire the satellite signal.
This tells the device where you're located.
After that, you can find simple directions to get to a new location by entering the address into your Garmin Nuvi.
If you find that your Garmin Nuvi has limited or no power, you will need to do some troubleshooting to get it to work.
Change the fuse within your unit's power cable.
If your Garmin Nuvi has no power, the fuse may be out, meaning the device cannot be charged.
Plug your Garmin Nuvi into the power supply of your vehicle and turn the vehicle on.
The device cannot charge and get power unless the vehicle is running.
Allow the Garmin Nuvi to charge fully.
You might be unplugging it from the power source too soon, which could cause the device to have little or no power.
Regulate the temperature of your Garmin Nuvi.
It may not function properly if the temperature is too cold, below 32 degrees Fahrenheit, or too hot, above 113 degrees Fahrenheit.
Aug 10, 2013 | GPS
I have a Garmin Nuvi 660. Serial # 12P414268. I turn on my GPS and I can't key in my PIN number. Nothing is working. I recently returned from a trip to Kansas. The unit worked great until we were...
Power off your Garmin 660 unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
To back up your Garmin.
  • From the garmin drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  • After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Garmin, but be sure to rename it 'temp.gpx'.
  • On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Garmin where they are actually stored
  • You can also try powering off the unit and hitting the reset button under the antenna, or try the information above but pressing firmly the lower right side of the screen.
    This should reset your Garmin then I would suggest updating your device at the Garmin site. I will attach a link.
    Thanks for using FixYa
    https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
    May 23, 2011 | Garmin Nuvi 660 GPS Receiver
    It boots to the screen where you agree to not use it in motion you press agree and it wont acknowledge the touch on the screen
  • This should reset your Garmin then I would suggest updating your device at the Garmin site. I will attach a link.
    May 20, 2011 | Garmin Nuvi 660 GPS Receiver
    I have a Garmin Nuvi 650 with an unresponsive screen...can anything be done? Thanks
    I have garmin nuvi 680 not responde el touch escring
    May 15, 2011 | Garmin Nuvi 660 GPS Receiver
    I got a Garmin 1300 for Christmas; when it is powered up, i get the Garmin name, then a green line begins from the left to start, Stops about one inch in and stops. It powers down and goes black. Help!
    A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
    To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
    Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
    1. Back up your Favorites.
    2. Perform a Hard Reset.
    3. Download and then run Garmin WebUpdater to replace its firmware / system software.
    I hope that helps.
    _______________________________________
    Garmin Nuvi 1300 Manual Download
    Garmin Nuvi 1300 QuickStart Download
    Garmin Nuvi 1300 Favorites Backup
    Garmin Nuvi 1300 Hard Reset
    Garmin Nuvi 1300 Webupdate
    Jan 16, 2010 | Garmin nuvi 1300 Car GPS Receiver
    How do i charge garmin nuvi 250 on my computer
    HI,
    I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
    1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
    step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
    step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
    step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
    Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
    GPS Logo
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
